Question about Kodak Cine Showtime Projector A30 8mm Movies Works Very Good Condition
Does the Kodak Cine Showtime Projector A30 show Super 8mm film?
Will the bell and Howell model 256 dhow super 8 film
No it won't.
http://store.tvedenlampmodules.com/Vintage-BELL-HOWELL-256-AB-8mm-HOME-MOVIE-FILM-PROJECTOR-w-LAMP-CONVERSION-P5123061.aspx
To be crystal clear; This is a Regular silent movie projector. It will not run, or play Super8, or Super 8mm movie films, with or without sound.
Bell howell autoload 8mm projector user manual english
Dec 05, 2016 | Cameras
Have split image when watching 8mm film video.
If my memory serves me correctly, you should have an adjustment knob somewhere... and it seems like it was marked "frame". Another caution: I assume you know that 8mm and Super 8mm are not interchangeable. However, some of the old projectors (like a Kodak I had) had a twist knob that would change the projector back and forth in order to play either film. Just some thoughts...
Dec 06, 2013 | Computers & Internet
THREADING FILM IN A ELMO FP-C PROJECTOR
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm.
Jan 10, 2013 | Sewing Machines
HAVING TROUBLE THREADING FILM - ELMO FP-C
Is your film super 8mm? If yes, then the red sprocket above the lens should be pushed in, and the bottom black sprocket will stick out. If you have regular 8mm, then the black bottom sprocket should be pushed in. If the sprockets are not in the correct position, push the green lever forward (towards the screen) then open the two orange tabs, then push in the correct sprocket. Once you have the correct sprockets aligned, close the orange tabs. How to tell if you have 8mm or super 8mm film: Look carefully at the film image. If the sprocket hole is next to the middle of the image, it's super 8mm. If the sprocket hole is between images, it's 8mm. If your green lever is stuck in the forward position, that's because the film is not threaded. Once your film threads correctly, the green lever will spring back.
I am looking for a free manual for the Eumig Mark 8 Projector. I have an old projector and want to show film of my late mother. Film is original 8mm film 'not' super 8mm. Unfortunately I do not know how to...
was there any chance of me getting a free manual or is this site just a money making idea, obviously if it sounds too good to be true..it usually is!
Sep 14, 2009 | Cameras
Problem with an 8mm Cine Projector. (A What ????)
Is there a camera or video club where you live ? one of the older members may have had experience of this, and be able to help you
Mar 21, 2017 | Raynox Cameras
Kodak Cine Showtime Projector A30 8mm Movies Works Very Good Condition Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
