Question about Mitsubishi WL-82913 82" Rear Projection HDTV
Need replacement lamp for Mitsubishi WLV-82913LP
Black screen
Sounds like you need to replace the lamp. An original Mitsubishi lamp will last 7 to 10000 hours. It's a no brainer to replace. Buy the lamp from Mitsubishi or a dealer. Do not buy one over the internet. Those are awful...
Dec 31, 2013 | Mitsubishi Televison & Video
I see no picture
Televisions covered: Mitsubishi DLP High-Definition Televisions:
C Series: WD-60C8, WD-65C8, WD-73C8
735 Series: WD-60735, WD-65735, WD-73735
736 Series: WD-65736, WD-73736
835 Series: WD-65835, WD-73835
Here's an online version of your televison's (94 page) "Owner's Guide":
http://www.mitsubishi-tv.com/pdf/ownersguides/WD-60735.pdf
It sounds like the lamp in your "Mitsubishi Lamp-Cartridge" blew.
If your TV remains under warranty, you'll want to call Mitsubishi at 1-800-553-7278, and you'll need to have (a) Mitsubishi Model number, (b) serial number, (c) TV purchase date, and you'll have to ship the old lamp module back to Mitsubishi so that:
"All lamps replaced under warranty must be returned to Mitsubishi where they will be inspected for defect verification."
Return old Lamp-Cartridge to:
Mitsubishi Digital Electronics America
1001 Cherry Drive, Suite 2
Braselton, Georgia 30517
If you have trouble finding your TV's information, you need better "Warranty Management". Warranty Management can be done with software, or on paper. You may even choose to toss all your Owner's Manuals into a box, with the receipts. In case anything malfunctions/needs to be reprogrammed/reset then the manual & spare parts/cables (in a large Zip-Loc(R) baggie or two) can be quickly located and consulted.
If you television happens to be out of warranty, a nice (expensive) new lamp module can be ordered from Mitsubishi by calling 1-800-553-7278, or by ordering online at http://www.mitsuparts.com.
Refer to pages 75-76 of your Owner's Guide for complete Lamp-Cartridge module replacement instructions (with nice illustrations).
Your TV's Lamp-Cartridge part number is: Mitsubishi 915B403001
Here's an online source for the Mitsubishi 915B403001 Lamp-Cartridge:
http://www.dlplamps.com/products/mitsubishi-dlp-lamp/mitsubishi-915b403001.html?gclid=CLzb6ciaiq0CFQdN4AodZkMonA
Note that with the dlplamps.com offerings, you can purchase the lamp only for $109, or the entire lamp-cartridge module for $129. So you can save yourself $20 if you're handy. Remember to keep all fingerprints off the lamp glass element - this small amount of oil will weaken the glass, and cause premature failure of the lamp. In the event that you get a fingerprint on the lamp glass, erase it thoroughly with rubbing alcohol. Alternatively, one may prevent fingerprints with latex gloves (make sure you haven't an allergy to latex, though).
If the reason that the lamp blew turns out to have been a clogged Lamp-Cartridge Filter (once you have the Lamp-Cartridge out of the TV and in your hand, you'll be able to easily see the mesh filter), then place a regular PM (Preventative Maintenance) of this filter on your calendar.
Dec 17, 2011 | Mitsubishi WD-60735 Projection Television
Mitsubishi 50 inch .lamp needed to replace lamp did status light now flashes orange or yellowish.
Was the lamp replaced? Have you gone in to the service menu to reset the lamp hours? Also what model is the tv -
thanks,
micheal
Feb 25, 2011 | Mitsubishi Televison & Video
SCREEN IS BLACK ,BUT HAS SOUND
this is most likely just a lamp issue this lamps a made to last a average life span of 2-3 years of use
replacing the lamp should fix your problem that is the first thing to replace in this cases
here are few good online stores that have the lamp you need
http://www.discounttvlamps.com/915P028010-Housing-p/mitsubishi-915p028010-enc-ph.htm
http://www.discount-merchant.com/Mitsubishi-915P028010-915P028A10-Lamp-Enclosure-p/mitsubishi-915p028010-lamp-enc.htm?1=1&CartID=0
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Nov 05, 2010 | Mitsubishi WD-62528 62" LCD HDTV
I have a Mitsubishi TV Model# wd-62528, the red light comes on on the lamp light
Need to replace a new lamp. Or if you still see picture, go to menue and reset lamp. I f no picture, need to replace a lamp.
May 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Oct 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Burnt out lamps
There is only one lamp need. If you keep your user's manual refer to ...how to replace the lamp. (I recommend to use an original mitsubishi lamp) process is kind or smooth path to the user, But if you are not feeling comfortable replacing it a serviceman can give you an estimate on it.
Apr 22, 2009 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WL-82913 82" Rear Projection HDTV Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
