Question about Compaq MS Windows XP Home Edition for PC
Registry disable we use windows xp pro. with service pack2 my windows registry is disable thrue virus problem how can we enable it
  • asif_19313 Jul 18, 2008
    due to some problem my winxpsp2 showing that registry is disabled when i type regedit.
Remove the virus if you don't have software for this then go to F-Secure (http://www.f-secure.com/en_EMEA/). Download and use regularly.
On the Registry problems go here: http://www.f-secure.com/en_EMEA/
GJ
Posted on Apr 28, 2009
    Scholar:
  • 116 Answers
Need more information, on the problem.
If your computer is still booting then your registry would still be working. So when you say its disabled, how do you come to that conclusion?
Are you just trying to use regedit? If so i can provide a download. If not just need to know  what message or  program is  giving problems.
Posted on Oct 11, 2007
SOURCE:
My note book starts too much slowly and mostly stucks it takes about 2 or 3 min to the starting window screen and 2 min in the welcome screen. kindly tell me the solution
It might be due to Virus.So please use a anti-virus software and try scanning the virus
To my knowledge , if you have just updated , you should be OK , MS say they have have fixed all their faulty patches .
Did you download all the security fixes ?
Here are some other things to try .
http://www.techspot.com/tweaks/winxp...rvices-3.shtml
http://www.techspot.com/tweaks/winxp...es/index.shtml
http://www.techspot.com/tweaks/wfp/index.shtml
If your system hangs about 2 or 3 minutes at startup, where you can't access the Start button or the Taskbar, it may be due to one specific service (Background Intelligent Transfer) running in the background. Microsoft put out a patch for this but it didn't work for me. Here's what you do:
Click on Start, Control Panel, Administrative Tools then Services.
Go to the 'Services' tab, find the 'Background Intelligent Transfer' service.
Disable it, apply the changes & reboot.
Or if you don't want to disable it .
Background Intelligent Transfer Service. Uses idle network bandwidth to transfer data. For the majority of Users this feature should be of little use & as such I'd recommend setting it to Manual. Those on highly active Networks may benefit from having this set to Automatic, although it may be worth testing out to see if it does.
http://rogier.xszone.nl/windows/wintricks.html
• Defragment boot files
The boot defragment option is usually enabled by default, but it may be disabled, or not properly enabled. If it's not working, XP may boot dog-slow.
To enable it:
- Edit HKLM\Software\Microsoft\Dfrg\BootOptimizeFunction, find the string called Enable. If the string value is set to N, change it to Y.
http://support.microsoft.com/?kbid=308041
Resources for Troubleshooting Startup Problems in Windows XPmag-glass_10x10.gif
http://www.blkviper.com/WinXP/servicecfg.htm
http://www.blkviper.com/WinXP/servic...#Network%20DDE
Enable Quick post in BIOS setup , as long as you have a have a lot of memory .
The normal memory test , is tested three times & that alone may take 60 to 90 seconds.
http://www.windows-help.net/WindowsXP/troub-07.html
http://www.tweak3d.net/tweak/winstartupnew/
Disable the Windows XP Prefetcher
Windows XP has a Prefetcher component, which shortens the amount of time it takes to start
Windows and programs. When trouble shooting either Windows or program start-up issues, it might
be helpful to disable the prefetcher, because it runs as a background service while other
applications are running or loading.
To disable the prefetcher:
Start the Registry Editor
Go to HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Control \ SessionManager \ Memory Management \ PrefetchParameters
Double-click the EnablePrefetcher value (remember the value that EnablePrefetcher is set to!)
Change the Value data to 0 to disable the prefetcher .
Close the registry editor and reboot the computer for the changes to take effect
When done troubleshooting, you can re-enable the prefetcher by changing the Value data to its
original value.
Values for EnablePrefetcher are:
0 - no prefetch
1 - prefetch applications only
2 - prefetch boot only
3 - prefetch both applications & boot (default)
I find 5 is best .
THANKS......
WITH REGARDS........
VAISHU
Sep 26, 2010 | Dell Inspiron Mini 10 Notebook
Tip
Enable the Registry Editor, Task Manager and Folder Options Disabled by Viru
Virus attack is common these days and we often come across the problems like Disabled Folder Options or like Task Manager and Regedit disabled by Administrator. These problems are nothing but virus activities. The virus has infected our system and stopping us from accessing these options.
Pressing keys Ctrl+Alt+Del opens up a dialog saying that “Task Manager has been disabled by your Administrator” whereas you are the Administrator yourself. It becomes very annoying when you think that you can fix this problem by going into the Registry Editor but it doesn’t show up. Even the Folder Options gets disabled.
This problem is generally caused by a virus named “Brontok” but don’t worry just use RRT (Remove Restrictions Tool) that can easily solve this problem. RRT is free and can successfully enable:
1. Folder Options
2. Regedit (Registry Editor)
3. Task Manager
4. Show Hidden Files option
The tool will come more useful if you use it in Safe Mode.
Download RRT
on Nov 17, 2008 | Microsoft Windows XP Professional With...
Task manager is disabled by administrator
So your task mananger isn't working, this may be a Virus, or simply some programs error? Anyway, If you have Windows XP Pro, there's a nifty user interface to directly edit the setting you want to repair. Click Start, then click Run and type in gpedit.msc: And press OK. This runs the Group Policy Editor. Once in the Group Policy Editor, expand in turn: User Configuration Administrative Templates System Ctrl+Alt+Del Options You should see the Group Policy Window, Double click on Remove Task Manager to change its setting: It should be enough to click on Not Configured and then OK and Task Manager is available once again. If you don't have Windows XP Pro, then you'll need to edit the registry manually. Click Start, then click Run, type in regedit, and click on OK. Expand these registry keys in turn:
HKEY_CURRENT_USER \Software \Microsoft \Windows \CurrentVersion \Policies \System You should see the key DisableTaskMgr in the right hand pane. Right Click on the DisableTaskMgr item: Click on Delete, confirm that you want to delete, and Task Manager should be available once again. One thing to note is that it's quite possible that if you're in an environment managed by a centralized policy, these settings may have no effect. Your IT administrator may set things up so as to disable Task Manager, and other things as well at the domain level. You'll need to ask them if this is the case.
Feb 17, 2010 | Microsoft Windows XP Professional
Legacy_rpcss disabled by malware in services menu and registry
I would try to restore your hardrive so its brand new and then try to install the software
Aug 21, 2009 | Microsoft Windows Vista Home Premium with...
Can't install XP service pack2 on my AcerPower f6 computer.
Did this machine have Vista intalled originally? I checked Acers' support page for your model and I didn't see a xp sata driver.
Apr 14, 2009 | AcerPower 1000 (AP1000EA380M) PC Desktop
My task manager has been disabled due to virus attack. help me
There is a registry hack to enable or disable Windows NT TaskManager. The same registry hack applies to Windows 2000 and Windows XP. Hive: HKEY_CURRENT_USER
Key: Software\Microsoft\Windows\CurrentVersion\Policies\System
Type: REG_DWORD
Value: 1=Enablethis key, that is DISABLE TaskManager
Value: 0=Disablethis key, that is Don't Disable, Enable TaskManager
As part of the enhanced management available in Windows 2000 and Windows XP, rather than risking a registry change, as an administrator you can enable or disable Windows 2000 Pro or Windows XP Pro's TaskManager using Group Policy Editor. This can be applied to the local policy. Note: if you are trying to override your organizations group policy, you can't. As soon as you re-authenticate to the domain, the domain or OU Group Policy will rewrite the registry setting. But if the TaskManager was accidently disabled or you need to control this item for a set of standalone boxes this is for you:
  • Click Start
  • Click Run
  • Enter gpedit.msc in the Open box and click OK
  • In the Group Policy settings window
    • Select User Configuration
    • Select Administrative Templates
    • Select System
    • Select Ctrl+Alt+Delete options
    • Select Remove Task Manager
    • Double-click the Remove Task Manager option
And as I mentioned above, since the policy is Remove Task Manager, by disabling the policy, you are enabling the Task Manager.
Mar 23, 2009 | Internet Grisoft AVG Security Full...
Disable Windows xp Desktop properties
To Enable/Disable for Current User
[Start] [Run] [Regedit]
Registry Key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
Modify/Create the Value Data Type(s) and Value Name(s) as detailed below.
Data Type: DWORD // Value Name: NoViewContextMenu
Setting for Value Data: [0 = Disabled / 1 = Enabled]
Exit Registry and Reboot
May 07, 2008 | Microsoft Windows Server Standard 2003 for...
System restore
Start the System Control Panel applet. Select the System Restore tab. Clear the "Turn off System Restore on all drives" check box to enable System Restore, or select this check box to disable System Restore. Click OK.
An alternative to the usual method of enabling and disabling Windows XP's System Restore feature is to use the registry. To use this alternative, perform the following steps: Start the registry editor (regedit.exe).
Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore.
If a "DisableSR" value doesn't exist, go to the Edit menu, select New, DWORD value, and create the value.
Set the value to 1 to disable System Restore or 0 to enable System Restore.
Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\sr to prevent the System Restore service from starting.
Double-click Start, and set the value to 4 to stop the service from starting or to 0 for normal startup. Close the registry editor.
Feb 07, 2008 | Computers & Internet
Windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
Open Questions:
See all Compaq MS Windows XP Home Edition for PC Questions
Compaq MS Windows XP Home Edition for PC Logo
146 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
