Question about Water Heaters
System in lockout
I have a gpsh 50 200 and the problem is that system is in lockout so i have no hot water.
  • 332 Answers
Depending on the age, you may need a circut board replacement, other then that if it has a blower on it unplug it, it will reset itself, if not you will need a circuit board
Posted on May 30, 2009
My ideal logic combi 30+ is saying ignition lockout and my radiatiors arent heating up as well as my water not turning hot. How can i fix this please?
Lockout is a safety feature. Usually a latching condition and needs to be investigated rather than blindly reset. (The Combi has a bit more intelligence.) With the ignition locked out, you can't hi-fire the boiler, so no hot water of either type. The 'L' should also show a code number - check your user manual (google) for more guidance.
I've had a lockout on a non-combi: it was caused by lack of circulation of central heating water through the boiler.... The system boiled and the trip tripped. The pump WAS running, but wear in a valve actuator resulted in the valve feedback saying valve open while it was physically shut.
Dec 31, 2016 | Water Water Heaters
ER3 error code on amtrol hot water tank
Simply means hot water heater called for heat for 1 hour and never rose in temperature or reach stepping, unit automatically goes into lockout. I would reset power
Feb 14, 2015 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
A O Smith GPSH 40 200 wont stay lit. Code lights are Green (labeled warm) + A + B
Copy following link for Intellivent service manuals, and error codes:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Wiring error
Check outlet polarity using circuit analyzer.
http://waterheatertimer.org/Troubleshoot-household-electricity.html#polarity
Check that outlet is fully grounded.
Check that ground wire has continuity to manifold tube (largest tube connected to bottom of gas control valve)
Mar 19, 2013 | Water Heaters
After years of problem free hot water the pilot light went out and now when trying to re-light the pilot light as per instructions it does not light although the spark is strong and hitting the ther
look at label on side of unit, then add a comment with Brand and type of gas water heater.
AO Smith tank-type, or Rheem tankless so expert can suggest best solution.
Tank-type:
Gas control could be bad.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Water heater is in lockout because combustion chamber overheated and tripped FV system because air intake is clogged.
Oct 10, 2012 | Water Heaters
Rheem Intelli-vent intermittently goes in lockout mode
Rheem does not post service manuals.
However AO Smith has posted relevant service manual:
Have you cleaned the air intake located under combustion chamber, and inspected for broken glass vial?
Rheem FVIR system uses glass vial that breaks if combustion air is slowed, and resulting combustion causes slow-moving venting of hot gasses, causing overheating that breaks glass vial.
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
Check gas pressure.
Replace gas control valve:
Oct 09, 2012 | Water Heaters
Hot water heater pilot is off. It's not gas,
You have tank-type gas water heater:
Open following link to watch thermocouple replacement.
Make sure new thermocouple sits into pilot flame. Instructions for relighting water heater are usually printed on side of tank.
http://www.youtube.com/watch?v=v0aBPsNg6vo
Gas water heaters need working thermocouple, adequate incoming fresh combustion air with no trace amounts of chemical, open vent to outside that drafts poison combustion product upward, clean burner tubes and combustion parts, correct gas pressure with no air in line, working gas control valve thermostat, no lockout condition such as tripped ECO caused by runaway heating and dirty combustion parts, and no lockout condition such as exposure to flammable vapors.
Open following links for troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
Jul 29, 2011 | Whirlpool Water Heaters
On the ideal c95ff the boiler the red neon lockout
overheat stat , does it come back on with reset ?best of luck
Jul 23, 2009 | Water Heaters
Rheem Pronto Hotwater Heater Error
Unplug unit from wall. Disconnect remote wires from circ board, and let unit set for about 5 minutes. plug back in. run water and see if unit comes on.
Jun 16, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
I painted the floor & my hot water heater (Reehm
The water heater is locked out. The following process should reset it.
1. Reapply power to the water heater and wait for 3 seconds for the system self-diagnostic check.
2. Within the first 30 seconds, the temperature dial must be rotated back and forth crossing the 120
degree mark at least six (6) times. This will reset the control and display a normal flash code
(slow blinking).
Mar 22, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
518 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
