Question about Car Audio & Video
Subwoofer moving wrong way possibly causing damage!
I have a 15inch hifonics zeus subwoofer running off a kenwood 1800watt monoblock amp and the problem im having is when i try 2 drop low bass frequencies my sub moves in and goes flat producing next to no bass at all and im no professional so i wanted to know what the problem is and what i could do 2 fix it? someone told me my voice coils are wired the wrong way but the sub runs fine usually but just the low frequency bass it goes funny for sum reason. i appreciate any help thanks
    Novelist:
  • 149 Answers
Hey i'm no expert either but maybe just maybe your amp has a subsonic filter on it which cuts out the lowlow bass maybe check that and either disengage it or turn it all the way down if it even has one thats all i can think of unless you have a ported box and going below the boxes tuning frequency other than that im as stumped as you are-good luck with it
Posted on May 09, 2009
I have a Power Acoustik Dem0n II 6000w amp. Every few seconds or so, it cuts off. In addition to the constant power outages, the amp is almost always hot. Can someone tell me what the problem might be?
be sure the amp is located in a well ventilated area as heat build up can cause a safety override to cut power once temp. reaches a certain point. amps do generate heat though so if you dont think its cutting out due to excessive heat building up, i'd definitely get a power capacitor to help keep a steady supply of electrical energy available for instances where the bass hits really hard or for prolonged periods of time. if you have a power cap already make sure it doesnt need to be upgraded to function properly. hope this helps!
Feb 14, 2015 | Power Acoustik Car Audio & Video
Protect light amp
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
would definitely look at getting it repaired. These new amplifiers can't hold water to an old school Zed audio hifonics Zeus.
Jul 31, 2013 | Hifonics XX-Zeus Car Audio Amplifier
Best amp for two l7 15inch speakers are 4 ohms
i personally like the audiobahn a.k.a. cheater amps ill go with the A2300hcx model
May 10, 2010 | Car Audio & Video
Does this amp have dual 2GA inputs-Hifonics XX-ZEUS
Mono amps have single power in so if it is stereo then it should have two.
Apr 25, 2010 | Hifonics XX-Zeus Car Audio Amplifier
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
Hifonics zeus z400 red diagnostic light blinks on a bench test ? whats that mean any one know.
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and or a channel or power supply and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 12, 2010 | Hifonics Zeus Z400 Car Audio Amplifier
Subs not programmed into dash...?
It sounds like the input gain on the amplifier needs to be adjusted.
OR if your certain this hasn't changed see if both of your RCA cords (Left and right) are working. I had a similar issue when the mono block AMP was only sending signal from the left channel to the amp which in turn was dropping the input load in half. Its all about isolation.
Simple way to test this is to adjust the L/R balance of your deck all the way left or right and see if the amount of bass changes. If you balance all the way left and you lose your base completely then you know your amp isn't getting signal from the left channel thus if you move it all the way to the right and the bass disappears then the problem is with the right channel.
Jul 05, 2009 | Kenwood 12" 4-Ohm Single-Voice-Coil...
I HAVE A ZEUS ZS12 350 WATTS AND IT HAS THREE HOOK UPS ON THE BACK HOW DO i HOOK THEM UP
This is a dual coil sub . Go to :
www.colomar.com/Shavano/dvc_spkr_wiring.html
There are several ways to hook up this type of sub. The web site will explain.
Jun 30, 2009 | Hifonics ZS12 12in Zeus Round Version Car...
Make the sub pop and hum and no rca wire are hooked in?
first off nice choice on the amp check ur power and ground connections make sure the main battery to bady ground is good if questionable add a new one cant hurt to have extra grounds from the batt to the body make sure the amp ground is as short as u can make it make sure its grounded to bare metal if any of these dont work u may have a prob inside ur amp
May 06, 2009 | Hifonics XX-Zeus Car Audio Amplifier
Searching for the right amp
a kenwood 1800watt d class mono block cost ruffly $600
Oct 04, 2008 | MA Audio HK15X2 Car Subwoofer
Car Audio & Video Logo
82 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
