Question about Dryers
Gas dryer wont trun off after drying
I have a ken more gas dryer it drys but wont shut off
  • 10,865 Answers
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Posted on May 09, 2009
Trouble with Maytag Legacy gas Dryer
Please provide the model number and I will see if I can figure something out.
It sounds like you have covered the common problems. Usually a motor is the cause for this problem, it gets hot and shuts down until it cools off. I have had some problems with the auto dry controls on the Maytags also.
Are you equiped to do some voltage checks if we need too? This would help in knowing where you have power when it quits.
Thanks/Mike
Dec 12, 2007 | Dryers
LGR7647 will dry fine but smells like gass only when it runs.
make sure the air shutter on the gas nozzle isnt completely blocked or changed positions as the flame needs oxygen to make combustion complete otherwise the gas wont burn completely and you will get a black smoke that smells like raw gas
Dec 06, 2012 | Dryers
I have a neptune dryer I bought from a used appliance store about 6 months ago. The cycle comes on but there is no hot air. Clothes are not dry after 3 full cycles. I am not even sure if its gas. Don't...
you will need to get behind the dryer and disconnect the vent tube, try drying a load of clothes with the vent tube disconnected if it drys then the tube is the problem and needs to be cleaned out. If it is not drying at all then it is a few things, I am assuming its electric here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Hi, I have a Maytag gas dryer MDL# LDG8200AAW and its great my wife would not trade it for one of the new ones at all. The problem that I'm having with the dryer is that it drys the clothes but it does not...
Correct, Your belief is wrong! Your wife's belief is correct, the best dryer ever made!
If this happens only when you are using it on an auto setting then it is probably an air-flow problem,a dirty exhaust system. Clean it out!
Jul 12, 2017 | Maytag Dryers
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Changing gas whirlpool dryer heating ailment
Before you do that try this pull the unit out from the wall remove the venting from the back run a load and let the hot air go intop the house if it drys fine you have a plugged vent going to the outside and it will need to be cleaned out (This is the most common problem for long dry time)
Apr 13, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
166 people viewed this question
Top Dryers Experts
