Question about Garden
John Deere Lawn Tractor LX176. Battery discharge
John Deere Lawn Tractor LX176. Battery discharge light remains on. Thought it was a bad battery but new battery is the same. My next quess is the flywheel alternator. Suggestions
  • Anonymous Mar 28, 2014
    electric clutch on blade ***.
    Sniper:
  • 197 Answers
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
  • 246 Answers
Hello:
It Sounds like the Stator/Charging Coils or the Voltage Regulator (if Applicable) is Bad and Requires Replacing.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
Tip
Mower belt diagrams 2
john-deere-54in
John-Deere-CA130
John-Deere-Gt235-54
John-Deere-LX176
on May 20, 2015 | Garden
How to remove the old lower hood on a john deere lx178
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
JOHN DEERE LX172 LX173 LX176 LX178 LX186 LX188 LAWN GARDEN TRACTOR Service...
Apr 29, 2017 | John Deere Garden
John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Sep 23, 2009 | Garden
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Aug 10, 2009 | John Deere Mower Blade 5 each
Discharge indicator light stays on.
I would start with a new voltage regulator which is located under the battery tray.
Jun 16, 2009 | John Deere Garden
Garden Logo
2,802 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
