Question about AO Smith 2 hp Swimming Pool - Jet / Well Pump Motor / Century B124
AO smith motor #C48M2EC11C3 need start switch
john224
  • 1378 Answers
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
john224
  • 1378 Answers
SOURCE: How to manually reset an AO Smith 2 hp motor?
If you did not press a reset ( and even if you did) the motor is damaged and that is causing the circuit breaker to trip. You need to have the motor inspected to see if the damage is repairable or if you need a new motor. A local electric motor repair shop should be able to take care of that for you. The thermal overload has reset itself if after cooling down the motor is trying to start but trips the breaker.
To be certain it is the motor, disconnect the line leads and be sure they are insulated from ground and one another. Turn the breaker back on. It should stay closed which confirms it is the motor tripping it when connected.
If for some reason the breaker still trips, there is a problem with the electrical circuit feeding the pump.
Posted on Jul 26, 2009
john224
  • 1378 Answers
SOURCE: Describe your AO Smith 1.5hp Pool Pump Motor 2
According to our Emerson parts dealer, parts for that motor and the motor itself are obsolete. They could not provide a part number to search for or an equal part either. We can quote you a new BN34 if you wish to contact us through www.arrowpools.net.
Posted on Aug 21, 2009
john224
  • 1378 Answers
SOURCE: I have a AO Smith Century Centurin Swimming Pool
A.O.Smith USQ1152.
Posted on Jan 18, 2010
john224
  • 1378 Answers
SOURCE: what do wire colors mean for ao smith dl1056
Thank you for posting your question here on Fixya.com.
White is common, Black high speed, blue medium speed, red low speed; Brown wires are for the capacitor; The remaining 4 are for selecting the rotation.
For details look at the AOSmith print here.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jul 31, 2010
Switched to new AO Smith B230SE motor for pool pump. Old motor had left-hand screw that held impeller to shaft. New motor does not have an opening for screw. Will impeller be fine without screw?
Did you try the Century A.O. Smith B230SE motor without the center screw? I'm having the same problem and I'm asking the reseller for advice. It would be great to know if I need the center screw is required? The impeller screws on the shaft, but is the center screw required?
Sep 17, 2013 | A.O. Smith SQ1102 Pool Pump Motor
Need to change a goulds 1.5hp motor from 120 to 240 volts
should have info on side of motor, some motors cant be switched
Mar 19, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
I have a Whisperflo Eplus 1.5HP pool pump. It has a A.O. Smith motor. the 50MFD 370VAC capacior is bad and needs to be replaced. Is the Capacitior a run capacitor or a start capacitor? Does it make a...
You didn't indicate exactly what AO Smith motor model you have, but most likely it's Capacitor start/run if it doesn't have a switch. The important thing is to replace with the same MFD as the old so you have the same starting characteristics. Here is a great link on AO Smith motors: http://www.discountpoolzone.com/poolmotor/pump_motor_university.pdf
Aug 13, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
There is not a point setting for air compressors. The pressure switch can be adjusted. Remove the cover from the pressure switch. Adjust the nut tighter for a higher cut off pressure or looser for a lower cut off pressure. It sounds like the compressor is trying tostart under load. If the unloader valve is not working, the compressor will draw excess amperage and do what you describe. The unloader valve releases the pressure in the cylinder at the end of the run cycle so the compressor can start the next run cycle under no load.
May 14, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
AO smith compressor motor missing toggle for duel voltage
Most motors will have a wiring diagram on them with numbers not colors, and show the wiring configurations for both voltages. If you do not have this then you may want to contact a motor shop and see if they can get it wired for you.
Nov 25, 2009 | AO Smith Air Tools & Compressors
AO Smith 2 hp Swimming Pool - Jet / Well Pump Motor  / Century B124 Logo
147 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
