Question about Sony STR-DE497 Receiver
SONY STR-DE497 receiver: is there a factory reset option?
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
  • 85 Answers
SOURCE: operating instructions for sony str-d565 receiver
this is a link just make sure to disable protected mode in internet explorer sometimes it has problems with links
http://www.docs.sony.com/release/STRD665.PDF
Posted on Feb 23, 2009
ginko
  • 19396 Answers
SOURCE: Sony STR-D665
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
  • 94 Answers
SOURCE: sony str db870 master reset
If the power of the Receiver is ON, press Power to turn OFF the power. Then, hold down the MODE + button and press the Power button together.
S.F Intialize appears in the display and all sound fields are reset at once.
Posted on Sep 22, 2009
adracamas
  • 344 Answers
SOURCE: I NEED TO RESET Sony STR D365 Receiver BACK TO
I believe what you want to do is as follows. Turn off the power supply. Hold the buttons 6, 7, 8. And turn on the power. The display should activate all options, then turn on and off a few times and finally display End. Then the memory should be reset back to Factory.
Posted on Apr 11, 2011
How do I do a factory reset on Sony STR-DA3300ES receiver when the published method in the manual doesn't work?
While holding down TUNING MODE, press POWER on the receiver. All preset stations will be erased when you change
the tuning scale.
See some test modes
MEMORY CLEARING MODE
All preset contents are cleared when this mode is activated. Use
this mode before returning the product to clients upon completion
of repair.
Procedure:
1. While pressing the [TONE MODE] and [DMPORT] buttons, press
the [POWER] button to turn on the main power.
2. The message "MEMORY CLEARING***" appears and the
memories are reset to the default values.
3. When done, the message "MEMORY CLEARED*"
If you are a geek then try the SUPER MENU MODE .
Understand how to enter and exit the menu,
then See if Super reset on page 25 helps
Sony STR DA3300ES Service Manual Page 25
Oct 07, 2016 | Sony STR-DA3300ES
The following buttons not functioning on the unit: memory, preset tuning and tuning +/-
it probably the button got stuck that's why it does not allow you to switch any other station remplace the butons that will probably resolve the issue.
Nov 27, 2013 | Sony STR-DE497 Receiver
Remote work properly
Make sure the batterys are good if so open the remote and check the led that send the signal it may be unsoldered
Oct 26, 2013 | Sony STR-DE875 Receiver
I NEED TO RESET Sony STR D365 Receiver BACK TO FACTORY SETTINGS, CAN THIS BE DONE??
Apr 11, 2011 | Sony Audio Players & Recorders
How to reset sony str-dg800 to factory settings
For the STR-DG800 you need to power off. Then hold power button 5 seconds. When "push entrer" appears on display push "memory/enter" button. System will turn off and reset.
Nov 17, 2010 | Sony STR-DG800 Receiver
No audio in channell a out put
Check your connectons on the back of the receiver as well as thoes to the speaker. Make sure the wire has not been cut, or pulled apart. Both A and B come from the same part of the amp along with center. The rear channels come from a seperate board. Rotate the switch and see if you hear the sound of the relays falling in the back.
Aug 31, 2010 | Sony STR-DE497 Receiver
When swicth on, it goes out after writing protect, can i do anything?
It goes into protect mode when it senses something wrong. First check the speaker wires for shorts or diconnect them as a test. Turn it on, if still in protect mode, the problem is internal and needs to be looked at by a tech/repair shop.
Mar 09, 2010 | Sony STR-DE497 Receiver
Sony str-de497 when plugged in no display at all but the power lite goes on where can i take it for repairs in qld
Any Radio Shack will send it to one of their service centers, a $20 fee for an estimate that goes toward the repair if estimate is approved. I don't know where qld is.
Mar 10, 2009 | Sony STR-DE497 Receiver
STR-V444ES just hums
Sounds like the output stage is shot.
Here are a few things to try. If there is an option in the manual to reset the unit to factory settings, try that.
If that doesn't work, disconnect all of the peripherals, and select the radio. If you get sound there, you may have a bad cable.
Beyond that I would say the amp needs repaired.
Cheeres
Jan 01, 2009 | Sony STR-V444ES Receiver
Sony STR-DE497 Receiver Logo
147 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
