Question about Kenwood Car Audio & Video
Kenwood wiring diagram
Putting a kenwood 155u into my dodge Dakota got my harness red to red yellow to yellow and black to black and still no power what do I need to do now
shaggyrat
  • 1224 Answers
SOURCE: install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
you have the memmory wire which is usually the yellow connected to the wrong wire it should go to a straight power red should go to accessory power now you should have wire harness basically its colors match to match the colors easy if colors dont match colors you messed up now the other thing is there is about 3 fuses from sterio to battery sometimes 2; on the back of radio and in the fuse box sometimes someone just adds the 3rd to the power wire in back check fuses if hooked up right simple check take ground power and the yellow memmory take sterio to battery with fuses on all 3 hook direct to battery nothing else if sterio powers up you know you have right wires if it doesnt power up you blew it
Posted on Apr 20, 2008
  • 4102 Answers
SOURCE: re sent wire diagram gat all messed up
Hi
have we spoke before in previous post?
the red can go to any 12v live peramanent such as wire to clock or other item that has power with ignition off and the same with the yellow if your putting these to the same permanent live say from clock you can join these to together red/yellow to red on clock
the black can go to any metal or neg wire.
This should then have your device working the only problem im looking at for you now is the pink wire as this stops you using the device whilst driving as it goes to handbrake but i need to find out if its live or negative.
You could just wire the red/yellow to live and black to earth then see if it switches on and works if not then let me know and ill see about the pink wire ok
Makes sure you use inline fuses on the live wires so as not to short the device out.
Make sure you know what is permanent live to put the yellow/red wire to.
It doesnt need to be ignition it only says this so you cant use it with ignition off but you can wire it into any live feed from clock or switches so its up to you what to wire it to its just the pink wire im concerned about.
PINK: does it tell you to put it to live or earth on handbrake switch?
let me know ok
Posted on Apr 21, 2008
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
SOURCE: kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Posted on Oct 26, 2008
  • 14 Answers
SOURCE: need wiring diagram
This is a general wiring diagram for most head units.
Should be what you're looking for.
Posted on Dec 17, 2008
2006 dodge dacota radio wiring harness
2006 Dodge Dakota Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Left Rear Speaker Positive Wire (+): Dark Green/Dark Blue
Left Rear Speaker Negative Wire (-): Dark Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Dark Blue
Right Rear Speaker Negative Wire (-): Gray/Orange
Dec 03, 2016 | 2006 Dodge Dakota
What is the blue and yellow wire on the wire harness for the kenwood kdc-138?
According to any wiring diagrams I have looked at for the radio in your vehicle (both the premium and base systems), the only wire that I see that could get pretty much anyone confused unless they know is a dimmer wire coming from your headlamp switch. The only reason I cannot be 100 percent sure is because according to the wiring diagrams it is a black and yellow wire but I don't see any other wire with yellow that could cause a question. To be sure you can always check at the connector on the headlamp switch and check for continuity but if I were a betting man I would put my money on this. I went on and gave you the wiring diagram for the base system (without an amp). Not sure how well you can see anything due to a size limit on pictures but I hope I was able to help.
Dec 02, 2012 | Kenwood KDC-138 FM / AM Receiver
I need a trailer wiring diagram for a 2000 dodge dakota sport
Dark green with red wires the left stop turn signal Dark green with brown is the right stop turn signal Black with yellow is the tail lights.
Sep 08, 2012 | Dodge Dakota Cars & Trucks
Looking fo wiring diagram for harness from pioneer deh- 2800mp to 1999 dodge dakota
Hello my name is Israel and I will be glad to help you. Please be sure to rate the solution. Good Luck. The diagram for the 99 Dodge Dakota:
Constant 12V+ Red/Blue Switched 12V+ Red/White Ground n/a Illumination Black/Yellow Dimmer Orange Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Brown/Yellow Right Front (-) Brown/Light Blue Rear Speakers 5 1/4" Rear Corners Left Rear (+) White Left Rear (-) Dark Blue/Red Right Rear (+) Brown/White Right Rear (-) Brown/Orange
This is for the stereo:
Sep 13, 2011 | Pioneer DEH-2800MP CD Player
Which is the hot wire on a 1999 dodge dakota trailer plug? is it the black and what is the red/yellow wire for?
On a seven pin connector the black wire is ground. There is no red/yellow wire, but there is a red/tan wire. That is the power supply wire. It is fed by the 40amp fuse number 6 in the power distribution center. Let me know if there is anything else I can help you with.
May 27, 2011 | 1997 Dodge Dakota
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
1997 dodge dakota truck radio stereo audio wiring diagram
1997 Dodge Dakota Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Blue
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Brown/Yellow
Right Front Speaker Negative Wire (-): Brown/Light Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Dark Blue/Red
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Orange
Also, this coudl be interesting: Dodge Dakota Trucks at 1996
Hope helps (remember to rate and comment this answer).
Apr 29, 2011 | Car Audio & Video
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
2006 kia spectra audio wiring diagram
This should help you out. Good Luck.
Radio Ground black - radio harness
Radio Ignition pink + radio harness
Radio Illumination blue/black + radio harness
Factory Amp Turn-on N/A
Power Antenna green/black + radio harness
LF Speaker +/- blue/red - yellow/black +,- radio harness
RF Speaker +/- black - yellow +,- radio harness
LR Speaker +/- brown - white +,- radio harness
RR Speaker +/- green/orange - blue/orange +,- radio harness
Jun 13, 2010 | Kenwood Car Audio & Video
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Car Audio & Video Logo
188 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
