Question about Cuisinart Dgb-900BC Grind & Brew Thermal 12 Cup Automatic Coffee Maker
Leaks over when making regular coffee not grinding
2 Suggested Answers
SOURCE: My DGB-500 Cuisinart Grind & Brew coffee maker leaks coffee
I found out that internally the water line that comes off of the heating element is made of a rubber/silicon material. The heating element is so hot that it scorches or dryrots the tube and it cracks causeing leaking. Sometimes it comes pouring out and other times it just is enough to make it a pain. I have taken the time to get my specialized screwdriver set and take off the bottom of the pot, but have not been able to find a replacement tube for it. (They also made the tube so that you dont have enough to cut the broken end off and put it back on and if you COULD do it, they also put an "X" in the original tube so if you cut it and try to put it on you cannot push it on far enough. Other than this, it was a great coffee brewer for me for the past four years. (Put baking soda and water paste on the coffee stain if you have formica counters. A few times of doing that and the stain will come clean)
Posted on Apr 13, 2009
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Brera: coffee grounds inside + internal leak
finer grind setting and non oily beans did the trick for me.......
Apr 17, 2012 | Gaggia Brera Coffee Maker
How much coffee would it take to make the 55 cups in this coffee maker, and can you use the same coffee as you use for drip machines?
Your model sounds like the West Bend 59055 - Large Coffee Urn, 60 Cup.
The User Manual for your coffer urn can be found here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
Instruction for making coffee can be found on page 5. For 55 cups is would take 3 1/4 cups of coffee.
Use an electric perc or regular grind coffee; if you grind your own this should be a medium to coarse grind.
Do not use 'drip' or finely ground coffee as this could plug the drain holes in the basket and cause the urn to flood.
Mar 24, 2011 | West Bend (59055) Stainless steel 60-Cup...
I clean with rice and it grinds coffee beans. Then I have to grind moRE RICE TO GET IT TO GRIND COFFEE AGAIN
Instead of rice, fill container about half full with regular table sugar. Grind that for 10-20 seconds. You should not only get coffee flavored powdered sugar but the sugar will soak up the flavors from your grinder.
Then simply clean as you normally would. Works great!
Mar 19, 2011 | Starbucks Barista Burr Grinder
After it is done grinding and starts to brew it leaks coffee all over my counter. I have tried stopping it after the grind turning off the grind and just brew and putting it on strong and less cups. But...
Try taking the lid to the carafe and soaking in vinegar/ water. Then use as strong a jet of water as you can get from your faucet to blast the crud out from the chamber in the lid. You'll have to try different angles, they did not make that part easy to clean. (I have the same one). Also try taking the grinding basket lid and separate the 2 halves, they just click together and make sure nothing is stuck in there. Good luck!
Mar 01, 2011 | Cuisinart DGB900BCU Grind and Brew 12Cup...
Cuisinart DCC-2000 coffee maker LEAKS all over my counter . How can I make it stop?
There are a few issues that could be causing this depending where it is leaking from.
The most common leak occurs from coffee grounds. If you over fill the basket or if you are using too fine of a grind (especially if you grind your own coffee) it can clog the filter.
Try using less coffee grounds. The MAX recommended capacity is 15 tablespoons. If you are grinding your own coffee, try a less fine grind. If using already ground coffee, try switching to a different brand.
If this does not work or you are leaking from another spot, clarify and we can try to nail down what the issue may be.
Feb 28, 2011 | Cuisinart DCC-2000
How do i make regular coffe with this machine. The type of coffee you get from cheapest coffee makers. Anyobdy can tell me what settings i need to adjust.
If you need a long cup regular coffee with top quality you should just add hot water in an espresso this called filter cream or americano. If you need the cheap quality as you mention you should adjust the grinder to make the coffee grinding more groase with this coffee will come faster and with pure quality
Feb 01, 2010 | DeLonghi Esclusivo Gran Dama EASM6600...
Coffee grinder clogging
Remove the grind chamber.
There is a black plastic pice sticking up in the area underneath where the grind chamber would sit. Lift it up, and you will see it is sort of like a hatch. It is probably clogged with coffee grinds.
Go ahead and clear out this chute, and see if it resolves the problem.
-Tha Mp3 Doctor
Mar 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Saeco Incanto not grinding
Hi Chris,
The leaking is your steam valve that has to be replaced, you can see this if you open the door and look up in the right corner there you will see water drip.
If not then you have a pipe or boiler leak.
How old is your machine?
How often do you descale the machine?
When you try to make a cup of coffee, starts the grinder for two seconds or is it dead?
Hope this will help you.
Jul 19, 2008 | Coffee Makers & Espresso Machines
Cuisinart Dgb-900BC Grind & Brew Thermal 12 Cup Automatic Coffee Maker Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
