Question about Roper RAS6233KQ Top Load Washer
Liquid detergent leaking from under control panel
For the past two days, I have noticed liquid detergent leaking from under the control panel of my top-load Roper washer. Any ideas?
  • 460 Answers
Am sending you this diagram to better knowlage of your michine.
this web includs parts, parts #
copy n paste
http://www.partselect.com/MultiModels.aspx?ModelNum=RAS6233KQ&searchTerm=&RefineSearch=0
"Did it solve your problem?"
Posted on May 09, 2009
The problem I have with my LG dishwasher is that a green thick liquid leaks out onto the kick board. I noticed this when the door is half open, I wiped it off but it returns all the time.
Is this ooze perhaps similar to the same color as your liquid detergent or wetting agent (Jet Dri) ? A leaky dispenser would allow these fluids to leak down inside the door where they would continue down and out along the lower door edge. The only other option involves removing the outer door panel to investigate inside the door assembly. There should be no other sources of this sort of material.
Nov 01, 2016 | LG Dishwashers
What is zenamix
Hello. You may visit below link for steps in preparing dishwashing liquid..
http://qousay.hubpages.com/hub/How-To-Make-Dish-washing-Liquid
ZENAMIX PASTE is a detergent concentrate pre-mix which contains complete anti bacterial ingredients used for dish washing , liquid laundry detergent and other household liquid detergent making it anti stain, anti odor and oil removers, all rolled to one, with a spacial additive of Gentle to Hands (GTU) for hand care, too.
Nov 18, 2011 | Dishwashers
Where does the liquid washing soap go into the tray
If you look at the tray, normally you'll see a divider with info as to where to put the divider, depending on the detergent you're using. Mine has 1 divider, but two slots that it can fit in. One position is for liquid dispensing, the other for dry detergent. Yours should be similar. If there is no such provision, you may have to just add the liquid detergent where the dry powder is added. We actually did it like this for a time before we saw the difference in the divider positions, and it didn't make any noticeable difference.
Best regards, --W/D--
Jan 23, 2011 | Maytag Washing Machines
What do i use for a roundup wedd killer spill?
From MSDS:
      SMALL SPILL: Soak up spilled material with paper towels and discard in trash.
      LARGE SPILL: Liquid spills on floor or other impervious surfaces should be contained or diked, and should be absorbed with attapulgite, bentonite or other absorbent clays. Collect contaminated absorbent, place in plastic-lined metal drum and dispose of in accordance with instructions provided under Section 13. "DISPOSAL". Thoroughly scrub floor or other impervious surface with a strong industrial type detergent solution and rinse with water.For liquid spills that soak into the ground, contact the applicable Federal, State and or County Health Dept. for disposal recommendations. If disposal is required then refer to Section 13 "DISPOSAL" for instructions.
      Leaking containers should be separated from non-leakers and either the container or its contents transferred to a drum or other non-leaking container and disposed of in accordance with instructions provided under Section 13 "Disposal". Any recovered spilled liquid should be similarly collected and disposed of.
      Do not contaminate water, foodstuffs or feed by storage or disposal.
      GENERAL PROCEDURES: Observe all protection and safety precautions when cleaning up spills -- see Section 8. "EXPOSURE CONTROLS/PERSONAL PROTECTION". For help with any spill, leak, fire or exposure involving this material, call day or night (800) 225-2883.
Dec 31, 2009 | Home
Which detergent for Haier HNS1260 washing machine.
Yes you can use liquid detergent, If your's is a high effeciency machine, use HE detergent. It cleans as well, but makes less suds, which can cripple a front loader. Alternative HE detergents can be made at home,if you're interested. They can be either liquid or dry. You can find the recipes on YouTube, with the search set to "Homemade Laundry Detergent". We make the dry version, and it works better than anything we can buy. It costs us .02 cents per load.
Back to your question, though. If you intend to use liquid detergent, look into your dispenser and see if there is a moveable divider that you can change for liquid or dry detergent dispensing. Set it to the appropriate setting if it does. If not, use very little detergent, and you may have to add it directly to the load, skipping the dispenser altogether. Another thing that you might consider is that, if you ever have to have any warranty type work done, and the tech discovers that you have used liquid detergent, they will want to void your warranty.
Aug 20, 2009 | Haier Washing Machines
LG 2277 Liquid Detergent Box & Insert
please put detergent into the main(left) side of the dispenser
Feb 15, 2009 | LG WM-2277HW Front Load Washer
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
There is a leak under my hood and i don't know what it is
The only clear liquid I can imagine in that area is brake fluid.How do your brakes feel?Check the master cylinder.
Dec 08, 2008 | 2000 Mitsubishi Eclipse
Roper RAS6233KQ Top Load Washer Logo
47 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
