Question about Kyocera Office Equipment & Supplies
How do I remove the hard drive from a kyocera km-2550?
I just need to remove the hard drive to secure the data. Does anyone know where the hard drive is located?
sir fixalot
  • 146 Answers
SOURCE: Kyocera KM 3050 - error C3300
Error C3300 is a CCD Automatic Gain Control issue.
It could be poor contact in the connector terminals from the SHD PWB to the CCD PWB.
It is more likely a defective exposure lamp or inverter board that powers the lamp.
Try lifting up the Document feeder so you can see the optics frame through the platen glass and turning off and then on, the main power switch to see if the green exposure lamp illuminates.
A better, but more complicated way to check the lamp is to enter the service mode and run the exposure lamp test simulation. I will outline this procedure below. BE SURE NOT TO MESS WITH OTHER THINGS IN SERVICE MODE OR YOU COULD RENDER YOUR UNIT COMPLETELY UNUSABLE.
To Enter Service Mode:
Hit the "Status" button
Hit the following sequence on the numerical keypad:
1 0 8 7 1 0 8 7
You should be in service mode.
Use U601 by typing 6 0 1 and then "Start"
U601: Turning the exposure lamps on
Description: Turns the exposure lamp on.
Purpose: To check the exposure lamp.
Display:
CCD: Main Exposure Lamp
CID: Document Processor Exposure Lamp (inside the feeder)
Method
1. Press the start key.
2. Select the item.
3. Press the start key. The selected lamp lights.
4. To turn the exposure lamp off, press the stop key.
Completion
Press the stop key. The screen for selecting a maintenance item No. is displayed.
After checking the lamp(s) operation hit "reset" a few times to back out where you can type 0 0 1 "Start" to Exit Service Mode.
Posted on Jun 03, 2008
SOURCE: Can't print on Kyocera km-2550
I have an HP 1350 all in one printer/scanner. It was printing fine until I wanted to scan a document. I pressed the scan button and now its stuck there. I can't get it out of scanning. I tried turning it off, unpluging and replugging. Can you help me.
Posted on Feb 06, 2009
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
cbtmaya
  • 84 Answers
SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Posted on Aug 31, 2009
mysticus_tam
  • 38 Answers
SOURCE: Error Code C6050
First you must get into the service mode by keying in 10871087
The screen will start blinking - then key 163 and the screen should read cancel or execute -select execute
when it is complete turn unit off then back on and see if that worked, if not buy a new fuser unit. They cost around $150,00 to $200.00 depending on who you buy it from.
Posted on Dec 21, 2009
Kyocera km 2550 displays system error Main switch off/on error code 3100
this code would indicate that the lamp assy under the glass is out of position,sensor has failed or the drive cable(s) have come off.
This will need a technicians visit.
Sep 16, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
Kyocera km 2550 error c0610
Replace the main PWB and check for correct
operation.
Oct 26, 2012 | Kyocera Mita KM-2550 All-In-One Laser...
How do you install new e-mail addresses on scanner for kyocera km 2550
Open the browser on your computer, type the Ip address of the scanner on the address bar, the page of the scanner will open, under scan to email destination, you can add or remove accounts.
Dec 01, 2011 | Kyocera Mita KM-2550 All-In-One Laser...
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
I want add a KM-2550 as a printer on an XP machine. I know what the host name of the KM-2550 is. The KM-2550 is definitely on the network because I pinged it from the XP. How do I find the name of the...
u can come to know from the server
where its physically installed
goto printers and faxes
then oen printer properties
and there is a tab named shared
see the name there
and write it
and then
u can add to the other macine
and can install
Jun 18, 2010 | Kyocera Mita KM-2550 All-In-One Laser...
I am trying to set up newtwork scanning on our Kyocera KM 2550 multifunction machine and I can't find in the manual how to do it?
cool... ok here is what you do goto usa.kyoceramita.com then downloads... then where it says choose product... choose legacy copier then choose product then... where it says select subcategories... select manuals you need the scan system f operations guides both the setup and functions editions...
Dec 22, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
How to you set up a Kyocera KM 2550 to scan?
cool... ok here is what you do goto www.usa.kyoceramita.com then downloads... then where it says choose product... choose legacy copier then choose product then... where it says select subcategories... select manuals you need the scan system f operations guides both the setup and functions editions...
Oct 15, 2009 | Kyocera Mita KM-2550 All-In-One Laser...
130 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
