Question about Acer PH530 DLP Projector
My Acer PH530 overheats and shuts down after 15 minutes.
I'll be watching something on my projector for about 15 minutes before the screen goes funny colors and the projector makes a funny noise and shuts down. I've taken it apart and cleaned it out once, which seemed to help for about a month, but now it is back to overheating.
Same here.
But i found a solution. I mounted a 80mm 12V Fan on the Air-Intake Side of the Projector, connected 12V Power and viola - no overheating anymore.
It's very loud but i got my Projector in an extra Room in my Basement-Cinema. So noise is not an issue for me.
Posted on Jan 17, 2010
Mine does the same. When it was still under warranty I kept sending it in to get it fixed, but Acer never fixed the problem (rather they caused more problems). I sent it in for repairs 4 or 5 times, but eventually the warranty expired (after they told me they would extend it from the dates of the repairs). I haven't found a solution. If you do please let me know. Anyway, I don't recommend this projector to anyone else. AND, I certainly don't recommend Acer's customer service. Their warranty is worthless.
Posted on Aug 06, 2009
I have a Infocus in1503. It shuts down after 10 to 30 minutes. When it does shut down there is no lights. In fact the power light goes off as well.
I seemed to have had the exact same problem... I had placed the projector on top of a small book (to raise the unit), however, did not rest the feet of the projection unit on the book and it overheated and turned off, as a result. (The bottom of the unit was making direct contact with the book which caused it to overheat since not any air was passing through between the two)
After letting it cool for a while and powering it up -- it would usually power off completely for about 15 minutes. After a little thinking, I thought it may be the lamp/bulb and waited a couple of years and bought one online that arrived yesterday.
I installed the new lamp/bulb this morning and it did the same thing. It powered down about a half hour later. Bummer.
I reset the machine to factory defaults and checked to see if it had the 1.03 firmware... It did
Then went through the settings in the setup area and turned off the 'prevent pic screen saver'... Reset the 'lamp hours'
I doubled checked the lamp/bulb installation... Turned it back on -- same thing -- it shut off after about 15 minutes or so... Then unplugged the unit and turned it over and took out the 4 or 5 chassis screws and loosened and took off the side panels and blew onto the fans and circuit board areas and gently pounded the sides to shake anything that shouldn't be there loose and put it back together.
i powered it back on and now it's been working for about 2 hours and 16 minutes!
good luck!
Nov 12, 2013 | InFocus IN1503 DLP Projector
Projector starts the goes off by itself.
Check the fan is working could be shutting down cause overheat
Oct 16, 2012 | Sony VPL-ES7 LCD Projector
Toshiba xp2 projector overheating
Better late than never for any other XP2 owners out there. I've gone through 1 lamp so far with very good results. The key to overheating is cleaning the fan out, i.e. it sucks in a lot of dust particles over time which accumulate on the fan blade and in the vents blocking good airflow. Take a good strong vacuum hose to every vent, then again right when you turn it on. This will get the fan up to speed quickly and assist with removing more dust internally. Eventually, you'll need to open the projector up and clean internally (carefully), but doing the above maintenance will prolong its life and extend the lamp too!
Feb 22, 2012 | Toshiba TDP XP2 DLP Projector
Dell 4100mp shuts down
It sounds like the fan in you 4100 is defective.
Jul 14, 2009 | Dell 4100MP Multimedia Projector
How to start my projector when connected to laptop? '
Turn on the projector and laptop and connect the vga cord to the projector and the laptop (making sure there is a secure connection so it is tight but not overtight) and hold down function when your operating system has started (windows only mac is different) and press either F1 F2 F3 F4 or which ever one has the picture,icon, of the laptop and the external display.
Jul 05, 2009 | Acer PH530 DLP Projector
Projector overheats after 30 minutes and shuts down
Is the fan in your projector still working in high speed or not spining?
Dec 15, 2008 | Sanyo PLC-SW30 Multimedia Projector
ACER PH530 COLOR WHEEL
http://www.mk-electronik.de/hersteller/PDFDokumente/Acer/Projector/PD520.pdf
Aug 27, 2008 | Acer PH530 DLP Projector
My Panny AE700U shut down & won't restart
HI there
This is a faulty Mainboard that will need either repair or replacement.
If a Projector starts playing on and off tricks I have found it to be 99% of the time a faulty Mainboard.
Apr 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Acer PH530 DLP Projector Logo
793 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
