Question about Yamaha YST-SW150 Speaker
When i turn the speaker on,it shuts itself off.help
  • 39 Answers
If it is an amplified subwoofer, then it is likely that the amp is going into protect mode.
It sounds like either the sub (speaker) is blown, possibly a fried voice coil, or it could be the amp itself, over time the caps on the PCB dry out and fail.
I would disconect the speaker (keep the two wires from touching) and see if the amp then turns on and stays on. If it does then the speaker is faulty, if it still goes off then there is a more serious problem.
Posted on Jun 14, 2009
    Problem Solver:
  • 15 Answers
Try turning it on and see if it shuts itself off, if so it is probably confused. I would put it in a dark closet for a week or so to teach it a lesson, then see what it does. Or you could unhook the speakers and see if it works fine, maybe your speaker wires are touching each other and grounding out something.
Posted on May 09, 2009
AM FM radio Compact Disc player o.k. for 30 sec after start, then nothing. Fuses o.k.
Maybe a shorted speaker causing the power amplifier inside the radio to shut down or a speaker wire shorted to chassis and last the internal amplifier of the radio cd set faulty by itself... set volume to zero power it off take out the radio cd set; remove the speaker iso plug leaving the power plug only in and power it on if necesary turn again the volume down to zero and wait if it keeps turned on it a speaker problem if it shut itself off again then you go for a repair or a new one
Apr 23, 2016 | 2002 Toyota RAV4
Before my Onkyo receiver ht-r591 keeps clicking on/off rightnow is dead , won't power on at all ...Please Help!!!
Hi Markes,
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com.
Oct 29, 2015 | Onkyo Audio Players & Recorders
Tvee model 25 wont shut off light goes red and after 3 seconds flips back on
The TVee 25 will turn itself on whenever there is an input. If there is no audio input it will shut itself off or you can manually shut it off. Or, you can select an input that has nothing connected to it.
Sep 24, 2012 | Boston Acoustics TVee Model Two TV...
Keeps turning itself off
If Both speakers are working at a low volume and you turn it up and it clips and shuts off you have one of 3 problems. you have over driven your speakers and one has shorted the voice coil but still will work at low volume, its a overload protection for ohms short in receiver. unhook each speaker and turn balance to the one hooked up and turn up receiver if it shuts off do the same with other speaker to determine which side is bad. 2 speaker wires are touching at speaker or receiver. 3 a bad receiver output transister. Good luck.
May 23, 2010 | Sherwood RX-4109
My Denon AV-3801 will just turn itself off if volume is turned up. I have checked for crossed wires and such,not sure what is going on. Any answers?
Disconnect all speaker wires at the receiver, then turn it back on. Turn up the volume. If it shuts down, it needs to be serviced. If it stays on, reconnect speakers one at a time and turn on the receiver then turn up volume. When you find the speaker that causes the receiver to shut down, disconnect the wire at the speaker and re- test. make sure wires are separated. If it shuts down, replace the wire, if it stays on, meter the speaker itself to check for a bad vioce coil. If you don't have a meter, you can take the speaker to any audio shop or Radio Shack and they will usually test it for free. Hope this helps.
Sep 27, 2009 | Denon AVR-3801 Receiver
MySony str-da5000es is showing error code 11 and shut off by itself after few seconds.check and disconnect all speakers, unplugged power from wall and still showing error 11. am missing something in here...
error code 11 (protector) - According to the manual, 11/PROTECTOR means, "Irregular current is output from the speakers. Turn of the receiver, check the speaker connection and turn on the power again." Most likely, a strand of speaker wire is shorted to the chassis at one of the speaker terminals.
Hope this helps !
Jun 17, 2009 | Sony STR-DA5000ES Receiver
My Onkyo tx-sr606 7.1 receiver turns off by itself
hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
Mar 06, 2009 | Onkyo TX-SR606 Receiver
Kenwood new sterio shuts off when turning up volume
You may have a short in a speaker. Check to see that the wire terminals on the speaker itself aren't touching any metal. Even 1 terminal touching metal will cause issues. Hope this helps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Kenwood KDC-X692 Car CD/ MP3 Player
Receiver randomly shuts off during play
This is the "Protect" mode. It is either a bad speaker, or not good ventilation, or a channel going out in the receiver. Please provide more details about the problem so I can help you better. How long is it playing before it shuts off, does it shut off even if the volume is low? Disconnect the speakers form the receiver and then turn it on and let it play without speakers, if it still shuts off then the problem is not the speakers. More information is needed to better diagnose this problem.
Jan 07, 2009 | Audio Players & Recorders
Marine stereo (Aquatronics) Turns on and then shuts itself off
aquatronics model ms-1000 led display lights and nothing else
Aug 05, 2007 | Aquatronics AMS602WR Coaxial Car Speaker
Yamaha YST-SW150 Speaker Logo
225 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
