Question about LG LRBN20510WW Bottom Freezer Refrigerator
We have a LG bottom freezer refrigerator we bought in 12/08 and the ice maker is not making ice but still sounds like it is and the water line is open. Freezer is freezing foods ok and the top of refrigerator is fine also. Model # LDC22720SW serial # 807MRFP04523.
    Scholar:
  • 70 Answers
Make sure water is gettig to solenoid vale on back. If so make sure screen is not plugged and solnoid is real opening. May need to test coil on valve. If it is not opening or froze off Ice marker will cycle several times a day as it is temp actuated.
Posted on Jun 29, 2009
My icemaker for the LG French Door/Bottom Freezer Model # 25770SW is making very little ice.
If the ice maker is producing ice poorly, making small cubes or too few cubes then it means your ice maker is probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that is not cycling properly.
First, check the water line that's attached to the back of the refrigerator. Make sure it is having a good water flow. If the flow is poor, that means you will have to, repair, clean, or replace the tubing or the shut-off valve that supplies the water in the ice maker.
Second, check the water-inlet valve. You will need to replace the water inlet valve if it has failed.
Third, check the freezer temperature. It should be 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
Lastly, check the ice maker mold thermostat. Make sure that it's cycling properly.
The above is what you need to check on........
I hope this helps....
Take care.
Mar 08, 2011 | Refrigerators
I have a LG refrigerator, Model LFX25971, and ice maker doesn't make ice. What is problem
it may have a plugged water filter or check the valve on the water line to make sure it is on if that doesn't work replace the valve and water line to the refrigerator
Feb 20, 2011 | LG ElectronicsZenith 5989JA0002G ICE MAKER...
ICE MAKER NOT WORKING LBC22518WW (LG REFRIGERATION)
Hello, just like your problem, our ice maker just stopped making ice. We solved the problem by unplugging the refrigerator for about 2 hours leaving the freezer door open.
It started making ice a few minutes after plugging it back in. Obviously the line that supplies the water had frozen and this allowed it to un-freeze.
We didn't remove any of the frozen items in the freezer, at the two hour mark, everything in the freezer was still mostly frozen.
Thanks
Jul 13, 2010 | LG LBC22518 Bottom Freezer Refrigerator
Not making ice error code 1f
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | LG LFX23961SW Bottom Freezer French Door...
LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
Jan 14, 2010 | LG LFC25760SB 25 Cu. Ft. Panorama French...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Maker Hookup for LG side by side with freezer on bottom. We connected the water line to the fridge to the connection in back.... both connections, the one up top and the one on the bottom. We are not...
ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
Aug 06, 2009 | LG LFX25971ST Bottom Freezer French Door...
Fridgew/ice maker. ice tastes like sulfer.
This sound like you need a water filter change to the refrigerator.
Aug 05, 2009 | LG LFC20760ST Stainless Steel Bottom...
Kenmore freezer on the bottom. Ice-maker switch is turned on but no ice is being made?
Check your incoming water line for kinks. Make sure the water valve is turned on.
Replace the water filter.
Check inside the freezer and make sure the ice maker power cord is plugged in.
Mar 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG LRBN20510WW Bottom Freezer Refrigerator Logo
258 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
