Question about Zebra Symbol DS9808 Long Range Scanner - USB Kit Barcode Scanner
Symbol DS8908 how to disable standby mode - Zebra Symbol DS9808 Long Range Scanner - USB Kit Barcode Scanner
Disable power saving mode
Sorry, but you will NOT be able to DISABLE the power saver mode on this printer. The printer will still go into "power saver mode", but it takes longer to do so, if you set diffrent as default time delay [ Two power saver modes: (1) print to standby mode 35 Watt, user-definable 1-30 minutes, default 3 minutes ; (2) print to powersaver mode 4 Watt, user-definable 5-60 minutes, default 10 minutes ].
See also:
Dell 1250C problems with sleep mode
Oct 01, 2014 | Dell 1320c Laser Printer
I have a rca clock and by error the time is set to wake me up how can I cancel this?The model RC46-B
Hello
To disable the wake up function completely; Press [Bell Symbol] [Music Symbol] & press '1' of '2' repeatedly unti no wake mode ikon [1-bell symbol, 1 music symbol or 2-bell symbol 2 music symbol] shows on large display. I can't include these symbols with this site, as I give you the details of the symbols.
You can download the manual of your Clock from the following website.
static.highspeedbackbone.net/pdf/RC46_DOC_Manual.pdf OK.
Jul 14, 2011 | RCA Audio Players & Recorders
My tv power comes on with a snowy black and white background but after some time it goes automatically into standby mode.
Hi camadino ,
You need to set the auto standby mode to a long time for e.g. 3 hours or disable it.
Check the settings for standby mode and you would be able to set it accordingly.
You could access the TV's settings via the panel on the TV or via the remote which comes with it.
Hope this helps ...:)
May 10, 2011 | Sony KLV32S400A 32 in. LCD TV
Lenovo t400 cannot boot. have "z" light only
Hi vincent,
I see that you have a "z" light indicator on the system when powered ON but you see no video on the screen.
The "z" Indicator means that the system is turned ON and ready to use but is in standby mode.
To disable standby mode on your system simply press the FN button for about 5 seconds on the system make sure that the machine is turned ON, this will make you system go back to normal mode.
Note:
For additional info on the issue the system can be put to standby mode by holding down the FN+F4 for a second or two this will enable standby mode on your Thinpad T400 and to disable the standbymode press and hold down FN for 5 seconds.
I hope that this will be of help regarding you concern, have a nice day.
Mar 30, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
The flash is in macro mode. What does that mean and how do I get the flash to turn on?
The macro mode is for taking pictures of subjects very close to the camera. The camera disables the flash in this mode. There's a switch on the left side of the camera, near the USB port. Slide this switch away from the flower symbol and toward the mountain symbol to switch out of the macro mode.
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
Moon
If the shape of the symbol is the cresent moon....then that is the "Sleep" shortcut key. It will send the hard drive into standby mode. In a lot of systems, this sleep mode can really corrupt and damage system files. I always recommend disableing sleep mode in the power options section of the control panel.
May 24, 2010 | Compaq Keyboard
How can i disable standby camera on Nokia 8800 because i can not take any picture thank you
just go on the camera setting and off it to the stand by mode.
_____________
Using Nokia 5800
Nov 11, 2009 | Nokia 8800 Cellular Phone
Lock mode. Green key plus 3 dashes.
I left set in lock.after some time the lock symbol disappears. the set is now in standby.now switch tv on by standby tact switch on front of tv.
May 11, 2009 | Televison & Video
No taskbar available after standby mode
This may be because your task bar is set to 'auto hide' so you will have to disable it.
please rate me. thank you.
May 23, 2008 | Computers & Internet
Printer driver vs standby
Indeed this seems rather odd, and also a inconvenience. However, after following up with some research I found following Microsoft Knowledge Base. In a nutshell, any one of the following may cause Standby mode not to function properly becasue of this printer: device drivers, a program running in the background which interferes with Standby mode, or a BIOS Power Saving setting which needs to be enabled. So you may have to continue disabling the printer, or contact the hardware manufacturer from the printer to find out if any updates are coming to resolve that odd issue.
Feb 06, 2008 | Computers & Internet
Zebra Symbol DS9808 Long Range Scanner - USB Kit Barcode Scanner Logo
48 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Lawrence Oravetz
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
