Device generic error
SOURCE: Hi I have a problem with RAM memory korg pa 800 in
If it says there is a RAM memory error, there is likely a bad module. If you installed these yourself, it is likely you have installed the wrong type or an incompatible configuration of the modules.
USUALLY the modules need to be identical in these synths. When upgrading, buy a complete set fot the unit and ones that are specifically guaranteed for it.
SOURCE: my pa 800 cant link with pc
Read the installation instructions very carefully.
OFTEN these devices need drivers installed that sometimes must have the USB cable connected, other cannot have it connected while loading.
I have even found some that one has to install while in "safe mode".
ALSO verify that you have the operating system in your computer that is required... Often older software will not work with Vista or Win 7.
Testimonial: "yes i have wind 7.........thank you very much :)bye"
SOURCE: KORG PA 800
Many of these pedal have more than switches. Some use resistors as part of a matrix. The chances of success are only 50-50 unless you rewire the FC01 to be exactly the same as the EC5.
SOURCE: Hi, I have korg
Korg pa 800 = poor quality product (I have the same problem) ,pa 2x it's better.
