Question about Acer Aspire 5500 5570-2609 Laptop
Aspire 5610 won't go past stage 3 configuration update
My aspire 5610 laptop did a windows update, but it doesn't go past stage 3. it restarts itself and when it starts up again, it is still at stage 3. I need to reformat the system but do not have the password, as the computer is 3 years old. How do I go about reformatting without the password. I was told I have to press one of the function keys to automatically reformat it, but which key and when fo I press it?
    Scholar:
  • 70 Answers
If you need to reformat the system, you can usually access Acer's built-in eRecovery by pressing Alt-F10 at the splash screen. Just bear in mind that restoring the system to factory specifications will erase the contents of your hard drive, so please ensure that your important data is backed up before doing so.
The "Vista Boot Loop" is a known issue though, but does have a solution, see here
If you are unable to use the repair portion of those steps, there is another workaround, but requires the use of other bootable media, such as Ubuntu (which you can download for free here). From there, try following these steps to get the pending.xml file renamed (see Comment #12 specifically, when using Ubuntu)
If you can solve it using the latter method, then you can get back into the system without having to reformat the entire hard drive and starting over.
Posted on May 09, 2009
Stuck at the Configurating updates page
alright, whenever you restart the computer press "F8" key again and again . you will get the option safe mode. select the safe mode option and press enter key. login with your user account and click on start control panel and you will get two option over there" security center" or automatic update" click on security center or automatic update and select the option "notify me but don't download update for me" and restart the computer in normal mode. if you still get the same problem then choose the the third option "turn off automatic updats" and restart the computer. you should be able to work on your computer.
thanks and best of luck.
Aug 28, 2009 | Computers & Internet
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
Configuring updates dont stop
I'll assume last known good configuration didn't work, if you press f8 and choose disable automatic restart on failure, you should see the blue screen of death with more info, when you reboot the next time,(you may have to hold in power button for 5 secs), press f8 and see if Repair my computer is listed on the Microsoft Startup menu, if not, insert a windows vista disk and restart,booting to the cd(should happen automatically, but look for a prompt to press a key) choose your language, then choose repair my computer, choose the windows installation, and you can try to use system restore to go back before the uodates were installed and updated, then disable automatic updating so it doesn't repeat.
Mar 26, 2009 | Acer Aspire 5315 Notebook
The laptop will not start up
This sounds like a bad battery. If the battery has a short within it, it will cause the power system to shut down. Replace the battery and see if that works.
Jan 30, 2009 | Acer Aspire 5100-3825 Notebook
Acer aspire 5610-4654 keeps shutting down
Did you noticed overheating (hot laptop areas, fans spinning like in crazy?)
Can you start the laptop again just after it shuts down itself??
Jan 18, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5610 boot issue
The Video Chip or VIdeo board was faulty, you need replaced motherboard or video board 9if it has), unless you can find components level repair tech near you.
Nov 27, 2008 | Acer Aspire 5610-4648 Notebook
My pc cant restart aspire 5610
Hi, This might be a solution:
get into setup mode (before booting) and set the settings to default.
Now, try installing the OS from the cdrom.
You may also want to check if the CD is not corrupt. try that CD with some other computer (to see it getting stuck at the same stage).
Sep 20, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5630
Seems like your VISTA upgrade didn't sucessfully upgrade itself from XP to VISTA. Seems like M$ update program detects your OS as XP and tries to install the SP3 for XP. VISTA only has SP1 released. Its currently stuck in a loop that it doesn't know what to do. Restart your laptop into safe mode by pressing F8 before the VISTA loading page comes up and go to Safe mode and backup your data and use the ACER RESTORE CD OR ACER RESTORE METHOD to help you reload your system back to factory defaults then upgrade back to vista without install any updates or connecting it to the internet.
This is my best solution to get you out of this weird and unusual situation.
Jun 30, 2008 | Acer Ferrari 4000 Notebook
My computer keeps restarting itself
  1. Start laptop
  2. When the laptops Logo page closes, start to press F8
  3. You should get a Windows Start screen
  4. If you get a Windows Logo page (the kind you normally get when Windows loads, then reset it and start again.
  5. On the Windows Start page select "Last known good configuration" and press enter twice
Hope that solves it for you =)
Apr 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5500 5570-2609 Laptop Logo
145 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
