Question about Car Audio & Video
Blown channel i have a 2 channel amp that was working excellent until one of my channels blew. I have some electrical exp. can it be repaired? if so is there a do it yourself way?
    Scholar:
  • 34 Answers
Its possible to repair, but you have to crack the amp open and prod around a bit. I found that the failure is usually in the power components or the MOSFET drivers. If you have 1 channel out, I would focus on the MOSFETS (if you dont know what they look like just Google MOSFET - they are the black 3-legged chips and are usually mounted to aluminum to disperse the heat). Some things to look for:
- burnt / melted solder traces (where the MOSFETS connect to the main board)
- disconnected leads (same place as above).
If you find any connection that looks suspicious, it wont hurt to re-melt the solder around the joint to make sure its a good connection.
Hope that helps...
Posted on May 09, 2009
I had my boss 2400 watt 2 channel amp hooked up in my car. I had one sub on each channel and one of my subs blew. I unhooked the positive speaker wire on the blown sub, everything was fine. Driving down...
If your amp started smoking, probably not. Due to your description, did the other sub really blow? I would hook it up to another amp to test it. It may have been a channel in your amp. As for repairing the amp, the parts and labor to repair will probably cost you more that to just replace the amp.
Sep 06, 2011 | Boss Car Audio & Video
My amp blew the 20 amp fuses. Replaced and they blew as soon as the radio kicked in. Took the back off to look for any burnt connections or blown open/expanded capacitors or resistors. It smells like...
Remove all the wires from the amp including the remote turn on wire. Once you do that, after about 30 seconds the amp will reset. Hook the power up first, then the ground then the remote. Turn the unit on and check for power WITHOUT the speakers hooked up. If you get no power by now it's a good chance that the amp is cooked. If you do get power, try hoking up your speakers first on one channel then the other channel and then bridged. If it cuts out or off when you touch the speaker wires to one channel or the other, then that channel is no good. Hope this helps.
Mar 17, 2011 | Kenwood KAC-728S Car Audio Amplifier
My pyle plmra 220 600 watt 4 channel amp blew out, pyler said it would be 50 dollars to send it in to them so i said to heck with that and oppened her up and found a capacitor blown, but when i replaced...
outputs also blown, go to ebay and buy a better amp form the same price you would have paid for pyle to fix that one, just keep playing with that one and you will get better at repairs, thats how i learned to fix amps.
Dec 13, 2010 | Pyle - plmra220 - Marine 600 Watt 2...
Mic channels 2 and 3 don't work no sound. mic channels 1 and 4 work okay as well as inputs 5-12. how can i fix this??
There is an internal f ailure and the unit will require servicing. To get by until you can get it fixed, you can get line transformers that will allow the mics to be used on the higher channels.
If you have inadvertently plugged a source into the :insert" jacks of these bad channels by mistake, that may have blown the input op-amps.
A lot of dis-assembly of the board must be done to get to the parts to repair.
Another possibility is if the sliders have gone bad... SAME prognosis for repair.
Dec 26, 2009 | Mackie 1202vlz3 12 Channel Mixer
Ht-r500 onkyo
When a receiver does this, it is know as the "protect mode". This keeps the receiver from causing more damage to the components in it, by shutting it off when it detects an abnormal amount of voltage or current.
If you had to replace the fuses, it is most likely that you have a blown channel in the receiver.
You put 8 amp fuses in, so I hope that the fuses that blew were 8 amps as well. If you put fuses in that are higher rated in amps than the ones that blew, you will most likely cause more damage to the unit than need be. If the fuses keep blowing, please stop putting new fuses in again until the unit is repaired. Every time a fuse blows, it is because of too much current is going thru the unit. Having too much current is a very bad thing for electronics, it causes components to short out and sometimes even catch fire if the fuse is higher rated than it is supposed to be.
To find out just what parts will need to be replaced, you need a multimeter and then you will need soldering tools to remove the bad parts and put the new ones in.
When an amplifier channel gets blown, there are normally around 5 to 10 parts that will need to be replaced. If you do not replace every single bad part in the channel that has blown, you will most times blow up all the new parts that you just put in.
If you have no experience with electronics, you really should take it in to a service center for repair. If you are willing to try it yourself, let me know and I will guide you thru the troubleshooting steps to help you identify all the faulty components.
Onkyo is very well made equipment and is worth getting fixed.
A blown channel can normally be repaired for around $100 to $150, just depending on the shops rates and the extent of the damage.
Let me know if you need more help.
Dave
Jul 26, 2008 | Onkyo HTR500 Receiver
Denon avr 2105 died (3 times) dead AVR2105 faulty avr-2105
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Jul 19, 2008 | Denon AVR-2105 Receiver
BLOWN FUSE?
If no warranty - remove amp and check sub to another amp to isolate speaker from internal amp. Either the amp blew a channel or subwoofer blew. JBL's are typically well built. Has this speaker often been pushed loud often?
Apr 23, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Marantz SR18-no sound
I have worked exclusivly on marantz recievers, for the last seven years, the loud 'pop' you heard, and smoke, was 90% that one of the amplifier channels, on the amp block, has blown, and consiquently the unit stays in protect mode. It will power up, and decode audio, and even show an f.m. stereo on the tuner, but you won't get the 'happy click' of the protection relays, until the channel is repaired. also replace the 5fd memory capacitor on the front micro board behind the front panel. If you have someone repair the channel, make sure that the tech resolders all of the connections on the molex connectors on the amp block. there are 10 of them, five male and five female, The bad solder on these are what caused the problem in the first place.
Nov 29, 2007 | Marantz SR-18EX Receiver
P10002 blown?
needs repair bad fets or outputs
May 08, 2007 | Rockford Fosgate Punch P10002 2-Channel...
Car Audio & Video Logo
119 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
