Question about Dell E228WFP LCD Monitor
Monitor becomes multiple colors then freezes
I was on my computer when suddenly I moved the mouse, and my monitor screen became multiple colors (not the screen itself) after that my monitor displayed "Entering auto power save mode" and I couldn't get back to the original screen. There was no way to disable the power save mode.
I decided to turn off my computer by using the power button, and unfortunatly my boot screen was messed up as well. Letters were all over the place, horizontal stripes ran across the screen. Can anyone help? Thanks.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Disconnect the monitor from the pc and turn the monitor on by itself and see if you can see anything on the screen if you do then turn it off. Make sure your computer is turned off and hook the monitor up to it. Turn the monitor on and then turn the computer on and let me know what you see.
SOURCE: Dell E173FP stuck in power save mode
What if both the monitor and computer are stuck in power saver? There is no way to get to the control panel. Then what?
Posted on May 14, 2008
  • 3940 Answers
SOURCE: No display.
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Make sure the proper input is selected
1: D-SUB for Blue VGA cable
2: DVI-D for White DVI cable
The option selected should be indicated on the power save screen.
If changing the input select and rebooting the computer have no effect an no video from the computer is ever displayed, then the monitor is in need of repair.
Posted on Jul 01, 2008
MooMadCow
  • 38 Answers
SOURCE: Dell 2407WFP Monitor losing signal and having colored line artifacts
To your problem number 1:
I would check to see what the refresh rate is on your main monitor. Especially after waking the monitor from sleep, Windows tend to forget the refresh rate settings on secondary monitor and set it to the same as your main monitor. If your main monitor is set at 75hz or something, it could cause the secondary monitor to display the "out of range" message. When you reset the "extend my desktop to this monitor" setting, it probably resets the refresh rate to 60hz again.
This can sometime be remedied by checking to see if the monitor drivers are installed correctly. A lot of times the video card driver also gets in the way. I've had a lot of experiences with ATI drivers behaving very sporadically with multi-monitor setups, where they will consistently change to "plug-n-play monitor" and thus reverting any custom setting I have.
As to your problem #2:
I've had a fair bit of experience with this as well. The fact that the line shows the same way regardless of the monitor's own tilting orientation, means the error is probably coming from the video card signal rather than the LCD panel itself. This usually is a foresight of a nVidia card that's about to break.
I've went through many, many nVidia video cards over the years. They all inevitably break over time, probably because nVidia relies strictly on third party vendors... and to stay price competitive the third party vendors cut corners wherever they can. I always get the same horizontal line error over time as you described here.
The only way to know for sure, is to get a replacement video card, borrow one from a friend if you can, and see if the same problem still comes up. It's very possible for this to show up on only one of your two monitors. Try switching the monitor output as well, to see if the line now shows up on the other monitor instead.
Posted on Nov 04, 2008
jesselohse
  • 128 Answers
SOURCE: monitor comes on but wont show picture
You should make sure the cable is plugged into the video port on the back of the tower. Also, if you have more than one video card, ie an "onboard card" and another card that was added later, try alternating one to the other and see if the other one works. You can identify video ports by finding the blue pentagonal plug. It also will be the only plug that your monitor cable fits into (that is describing a VGA cable, a white cable is a DVI cable and is even easier to identify.) You might also want to make sure the video card wasnt jostled out of place. The final solution could be you have developed some bad memory modules, or the memory was jostled out of its slot during the move.
Posted on Jan 03, 2009
  • 285 Answers
SOURCE: My new Dell flat screen
You'll need to troubleshoot a little. SOmething may be broken, but you'll need to find out what. 1: Try the monitor on another computer, see wether it will work on that one. If it doesn't, the monitor's broken and you're probably going to need a new one. 2: If the monitor does work, put it back, but now use another cable to connect it to the PC. If that fixes it, your cable was broken. 3: If not, you could try to switch the graphics card in the PC with another one. Do not attempt that, however, unless you know what you're doing. If you don't, get someone you know to do it for you, or take it to a computer shop. If the PC will boot with another graphics card, the old one is broken. 4: If not, it may be your motherboard that's broken. Repeat step 3 with it. These steps should fix your problem. If not, please post back here. Regards, Yannick.
Posted on Jun 07, 2009
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
My monitor suddenly become black
If your PC is still running there could be two problems. One is the monitor, check to see if all the cables are plugged in well. Power cable from the wall and data cable coming from the back of the computer, if you have another PC close by test the monitor on that computer if not working on the other PC also, its the monitor=bad. Otherwise you can assume it was your video card though that is rare because of excessive video usage such as games and videos all at once. If you fail to solve this problem the monitor may have expired, a virus may have infested, the video card may have shorted out considering all the other possabilities are nulled.
Aug 23, 2012 | Computers & Internet
Hi! My monitor suddenly became yellowish. It is not showing white color anymore. Could somebody help me? Thanks!
You can check the connection at the back of your PC on where the monitor is connected to. It may be loose.
Hope the above helps. Good luck!
Jul 13, 2011 | AOC G2016WA2 LCD Monitor
Multiple lines on color running through image
if you have xp it should let you go back to a point where it was working correct. know what talking about? do that.
Aug 16, 2009 | HP w2207 Monitor
Suddenly hor. lin. became "narrowed", smell of overheated element
try a good slap most times it works
u may have to try looking at options to change the monitor soon too, its a sign to say the monitors's getting old
hope this helped
pls rate
Jun 29, 2009 | Samsung SyncMaster 900 SL Plus (White) 19"...
My flatscreen dell monitor fades out to dark gray, sometimes pink
Its definetely the monitor thats having a problem. when it blacks out during th monitor self test. i suggest you can ask for a replacement monitor.
Mar 19, 2009 | Dell E193FP 19" LCD Monitor
NEC flat screen monitor reset screen keeps popping up.
Call 800 836 0655 and ask for directions from tech support.
Nov 14, 2008 | NEC AccuSync LCD71VM 17" LCD Monitor
Computer freezing- blank white screen
Check your connecting cables to the monitor. They can become loose or you may have a cracked cable.
Jul 13, 2008 | HP Computers & Internet
Color monitor
hi check 4 any magnetic induction near the screen (transformer ,speakers) and move it away windman
Feb 06, 2006 | ASTVision 7L 17 in.CRT Conventional...
Dell E228WFP LCD Monitor Logo
324 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
