Question about Mitsubishi HC1600 Projector
Hc1600 lamp shutdown, replace lamp
Lamp shutdown
Does anyone have a motherboard for a hc1600?
I have a HC1500 Mitsubishi projector, I want a mainboard ...
www.fixya.com/support/t25341711-hc1500_mitsubishi_projector_want
Dec 27, 2014 - Can anybody help me to find one. Brought one mainboard on ebay, i got HC1600's motherboard, HC1600 has a different color wheel from ...
Jan 28, 2016 | Mitsubishi HC1600 Projector
Hln617w1x/xaa keep shutdown in 5 to 10 minute,picture kind of bleeding??
Its a common problem. The lamp needs to be replaced.
Call 1-800-samsung & choose the parts dept.
For the replacement lamp it cost $149.99 plus tax & shipping .
You give them the lamp code ( red sticker on the side of the tv) , they send it out 5day shipment.
Local tv repair services can install it for an installation fee. This will save money apposed to ordering through a tv repair shop who charges an order part fee plus etc...
Oct 17, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Picture way too dark to watch comfortably. Have already adjust all settings to maximize brightness. Bulb was replaced late last year and says 1,000 hours have been used but projector has not prompted me...
Unfortunately dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image.
Aug 06, 2011 | Mitsubishi HC1600 Projector
Recently, out of the blue, my HC1600 projector has been failing to project any image. It makes a clicking noise...then stops...makes another clicking noise and proceeds to flash a green and (stationary)...
Probably a power supply problem. Most likely, there is a power transistor or relay that is not properly powering the light or other equipment. Check the warranty on the device, get a new one if you can. It won't be easy to fix.
May 03, 2011 | Mitsubishi HC1600 Projector
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Lamp is not coming on. It was replaced recently Benq 8720
Check in your instruction Manual about pressing a button sequence while starting up. Some projectors do not actually know when you have changed the lamp, so you have to reset the lamp timer by pressing a button sequence. Often a genuine replacement lamp will have an instruction set which comes with the new lamp ( If you still have it !! :) You may have replaced the lamp but not reset the counter and it has shutdown because the counter has reached a critical umber of hours.
Jan 02, 2010 | BenQ Office Equipment & Supplies
What does the status light mean on my hc1600? won't power up
This could be due to a blown lamp in the unit or a temp control unit such as a bad fan or what not. You may want to take it in and have this looked at if I where you. This light is telling us its ether the lamp or the temp controll unit such as fans that has given out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 12, 2009 | Mitsubishi HC1600 Projector
How do I mount the HC1600 projector
there are three screw holes on the bottom of the projector, 2 in the back by the feet and one in the front. they take a standard size, I think it is a 6x4....
I had a infocus projector mounted to the ceiling and took it down this weekend and put the hc1600 in using the same screw and same adjustable ceiling mount.
Dec 24, 2008 | Mitsubishi HC1600 Projector
Mitsubishi HC1600 Projector Logo
26 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
