Question about Oregon Scientific AWP131129 - AW131/AW129 Wireless Meat Thermometer Replacement Probes
No current temp - Oregon Scientific AWP131129 - AW131/AW129 Wireless Meat Thermometer Replacement Probes
Inside the battery case is a "reset" hole. Use a paper clip and push it in while the temperature probe is on. The screen will flash and the unit will synchronize once again with the probe.
Posted on Aug 18, 2015
What cause a transmission shift solenoid to over heat
most common reason would be excessive current or internal short
they will be at the same temp as the oil but they are designed to operate at that temp
Jun 14, 2016 | Cars & Trucks
A short while after turning the unit on (AQV24V) it displays the error code E4 64. does mean? Thanks
  • Samsung E464 Code=IPM Over Current
Measure the current into the condenser to see if this is as per name plate,then check the gas charge
Nov 22, 2014 | Samsung AQV24VBE Vivace Wall Mounted...
Outside temp stays at 49*, can I reset it to get current temp?
There is an ambient temp sensor behind the grill that might be in need of replacement.
Aug 02, 2014 | 1996 Oldsmobile Cutlass Supreme Coupe
Coolant temp sensor location
Based on your question, I am assuming that the coolant fans are running? They should be, well they should if the temp gets to the a certain level. Not all cars have only one but some have two fans set up on different temp on/off. If you wish to check them to ensure they are running, you can check the electrical current from the temp sensor to the fan switch to ensure there is current going to the fans, obviously if not...that would be the problem. check out this video with all of these how to do yourself described....
Apr 01, 2014 | 2004 Ford Crown Victoria
This is my second attempt. I have a GE Profile
After you set it, the display goes back to showing the current temp. Just wait awhile and current temp displayed should change to the temp you set once it has had a chance to adjust. Give it a few hours.
Feb 19, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The temp. is running around 186 degrees
without check operating temp and knowing your current weather temp and driving that does not sound too out of normal. If opperating temp is over 20 degrees lower check thermistat and fan function
Mar 06, 2010 | 2001 Suzuki GSX-R 600
Install a digital outside temp gauge
To wire in a digital temp into your current system would require a lot of patience and schematics i dont even know where to begin to look for. It would be fastest and cheapest to buy the digital temp gauge and mount it on your dash board.
Nov 06, 2009 | 1994 GMC Safari
The refrigerator temp keeps returning to 65 after I set it at 34.
After you set the temp (at 34) the refrigerator display changes to show the current temp inside your refrig. (apparently it was 65) As the unit runs, this display will lower until arriving at the set temp.
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I replaced a compressor today filled everything properly.also replaced the capacitor and the contactor. the compressor is getting really hot and it keeps tripping the breaker. do you think its a bad...
I have some question:
1. Is the location of your outdoor unit have no any obstruction? Means that air out of the outdoor is not short cycling into the air in.
2. Did you check the current reading during start up of the unit? Is it like the name plate current reading?
3. Did you check your voltage reading in your unit during operation? It should be plus or minus 10 percent in the unit voltage rating.
4. Are all of your terminal clips and terminals are tight.
During unit operation you should get the fallowing data. So that we can know what really is the problem.
Suction press-
Disc. press-
current reading (actual)-
current reading (name plate)-
Voltage reading (during operation)-
outdoor air out temp.-
outdoor air in temp.-
Ambient temp.-
Aug 07, 2008 | Heating & Cooling
Oregon Scientific AWP131129 - AW131/AW129 Wireless Meat Thermometer Replacement Probes Logo
471 people viewed this question
Top Oregon Scientific Home Experts
Donni Steen
Tom Chichester
Are you an Oregon Scientific Home Expert? Answer questions, earn points and help others
