Xerox error codes
What does error Code 099-880 mean?
  • 2072 Answers
SOURCE: I have error code 07,010.43:41518 What does it mean?
That is caused by the print head not pivoting from home to print position.
Here are the probabilities.
1. The staineless steel pivot block, that the print drive shaft goes through has had some, most likely yellow ink seeping into it and had made it slow to move back and forth. That is the most likely issue.
2.The machine was unplugged or there was a power failure and the print head wiper blade has tacked to the print head.
3. The cables to the print head are hanging up not allowing free movement of the print head.
4. The Media path motor geat chain is out of timing. That is unlikely, but a possible cause.
The easiest way to prevent that code is to make sure the printer is level front to back and side to side.
Also, the print head is possibly bad.print head, but unlikely.
Posted on Jan 18, 2008
yalmer
  • 549 Answers
SOURCE: Xerox phaser 7750 error code
Click on this link at xerox.
Posted on Apr 22, 2008
SOURCE: Xerox Doc12 10-386 error code
10-386 Error
Posted on Dec 01, 2008
goodgold
  • 389 Answers
SOURCE: XEROX COPIER XC865 HAS AN H4 ERROR CODE HOW TO
H4Fuser temperature too low. Must be reset in diagnostics
Posted on Dec 19, 2009
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
What does error code 99,013.00:49569 mean xerox 8570 color cube?
Process Drive Fault"
Do you have another kit you can take from another printer.
Switch the printer off.
Swap out the kit with the one from the other printer.
Turn it back on. If it clears the fault when the printer is ready put back the new kit
Aug 14, 2015 | Xerox Office Equipment & Supplies
Fault code 042-325 on xerox 6280 color printer
error code 042-325 on xerox mean the problem is the main drive motor.
Jul 22, 2014 | Xerox 6280DN Laser Printer
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
Error 016-311 xerox workcentre M128
This error code means the Scanner is not installed. The reason for this code could be a bad or diconnected interface cable, or corrupt system software. Check the cables for connectivity. If the problem persists, it will probably require a call to Xerox service. 800-821-2797
Nov 08, 2009 | Xerox WorkCentre M128 Copier
Xerox 5750 error code 005
this error comes from fuser unit u have to change fuser unit
Aug 19, 2009 | Xerox DocuColor 5750 Printer
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox 8500n with error 13323.47:23971
13,323 is a Printhead Reservoir Temperature Faults . One of 3 things. In order of likeliness.
1. Print head has failed
2. Cable to the back of the print head is loose.
3. Electronics module has failed..
What that code means is that once the ink melts and flowes into the print head, the print head is not maintaining the proper temperature.
Nov 13, 2008 | Xerox Phaser 8400 Laser Printer
That is a fuser overheat. Make sure that the paper path module is securely locked into place.
Look for a piece of paper wrapted in the fuser.
Or replace the fuser itself.
Apr 11, 2008 | Xerox DocuColor 12 Color Copier
Xerox 8400 error code 37,063.45
Vpp measurement too low.
The printhead power cable may be disconnected.
Xerox All error booklet download LINK
Please rate as Thankyou
Dec 26, 2007 | Xerox Phaser 8400DP Thermal Printer
98 people viewed this question
k24674
