Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Continueus green flashing light
Recently my TV picture and sound would go blank and the power/standby light would flash green. It would flash continuously until the picture and sound came back on. It would go blank for about 10 seconds, then be ok for about 5 minutes. It;s a continuous cycle. Picture good for a few minutes, then fade to black. I tried everything the sony website recommended, including resetting the TV. I really don't want to pay the big bucks to have it repaired if the only problem is something simple. Could it be the Lamp is starting to go out? Please help. Thanks
  • dphill2000 Oct 16, 2007
    A new lamp fixed this problem. I was told that a lamp only has a one year life. If your lamp is over  a year old, you may want to start there.
  • 105 Answers
I have seen weak lamps do this. this would also be the first thing the servicer would replace. worse case scenario you would have a spare lamp on hand...
Posted on Oct 14, 2007
When I turn on my 50" Plasma TV the light goes from red to green. The Green LED flashes 14 times then solid. There is a white raster but no picture or sound.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 16, 2015 | Zenith Z50P3 50 in. Plasma TV
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
Jan 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Hello, I have recenty acquired a Philips CRT 29PT9420 Television. However. when i attempt to turn the TV on, the light at the bottom of the TV (Standby, On, Off light) flashes between green and red for 2...
Switch the TV on: Press the power switch A on the front of the TV. A green indicator on the front of the TV lights up when the screen is on. If the indicator is red, press the
-CH + keys on the remote control.
The green light blinks every time you press a key n the remote control.
Ref. link:
https://www.manualslib.com/manual/173137/Philips-29pt9420-69r.html?page=4#manual
Oct 11, 2017 | Televison & Video
KP57WV600 SCREEN TURNS GREEN THEN BLANK
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
  • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
  • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
  1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
  2. Unplug the TV power cord from the electrical outlet.
  3. Let the TV remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
  5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
50 Sony Projection LCD TV - picture off and on
I recently had a proview television delivered to my home from rent-a-center they said they lost the remote and brought it any way. Need I remin you this was suppose to be a replacement television from the last television we got that only lasted a week and then blew out. Now they did not explian much just said they don't have tghe remote about an hour after they left the tv went blank and we have no remote or power button. Tried looking it up on the internet the procedure to turn it on because I honestly just don't know and can't get no answer. Is there somebody out there that can explian how this television works?
Jul 04, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Standby/power button blinks with no picture or sound
id take it and have it repaired. people on here can tell you what they think it is but no one knows for sure what is causing the problem. a repair shop can guarantee the repair.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Blank Picture, Sound OK on Sony TV
Hello, there can be a contact problem in power supply, deflection or RGB stage. Please ask the tech to repair it for you. Best regards, Arpi
Apr 22, 2007 | Sony KV-27V22 TV
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
153 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
