Question about Samsung Electronics Samsung 40 Eh5000 Ledlcd Tv, 1080p,
I have a samsung UA32EH5000 led tv its. it is a big ... Power button blinks red SIX times
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
My KDF-55WF655 power led blinking red six times.
It looks like your power module is on the blink. Do you get any picture?
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
What's six red blinks at sony tv?
Hi, [Error code 6. LED flashes 6 times]. Malfunction of inverter or overcurrent protection....regards Sean
Jan 15, 2016 | Sony BRAVIA KDL-32BX330 32" 720p HDTV with...
My 55" plasma Samsung tv model number PN51E450A1FXZA. The red power standby light is lite but when you hit the power button it blinks and returns to a solid red with no picture or sound
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 06, 2015 | Samsung Electronics Samsung 51" E450...
Why does it have six red blinking lights?
Hi Tim
In my opinion
No... the LED's are doing their job
Error reporting
Modern TV's are computers and try to indicate where a problem exists.
Does it need a Firmware upgrade?
Red green or orange lights are on or blinking on the TV
Sep 22, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
What would be the solution for six red light blinking after switch on the tv?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
May 14, 2014 | Sony BRAVIA KDL-46EX700 46" LED TV...
Hi I have a samsung UA32EH5000 led tv its flickering can anyone help me fix this problem thanks alot
it is a big problem i heave a 2 solution power supply board its 1-st or signal board but not on the 1-st place
Nov 05, 2013 | Televison & Video
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
Sony kdl46ex500 red power light blinks six times
Most probably there is a problem in the power supply and it is going on standby protection mode. You may have to search for a service manual from open websites and look through for the error code indicated by the led blinking, to be very sure. Unfortunately I do not have one with me.
Jul 07, 2012 | Sony KDL46EX500 46 in. HD-Ready TV
How to configure UET-606 Universal remote for NIKAI LCD TV?
Get the UET-606 Remote
1. Make sure its switched on
2. Point the UET-606 Remote towards the TV
3. Press the SET + TV button at the same time - the Red LED on Power will Illuminated solid Red
4. Press the SET Button again while still holding the TV button
5. the Power LED will begin to blink red
6 Enter the code 136
7. Press the Red Power button several times [sometimes 60 times] until the TV set resets itself
8. if the TV resets itself - point the remote away from the TV set and press any button or the SET button until the Power LED stops blinking
9. you are now ready to go
Aug 20, 2011 | One For All URC 7740 Remote Control
Samsung Electronics Samsung 40 Eh5000 Ledlcd Tv, 1080p, Logo
48 people viewed this question
Top Samsung Electronics Televison & Video Experts
Bob Brad
Level 1 Expert
matt martin
matt martin
Are you a Samsung Electronics Televison and Video Expert? Answer questions, earn points and help others
