Question about Ovens
How to lite old oven pilot lite
Have a 1950's Chambers Model C range. For years the oven could be ignited with a match and then would work until finished. It sat for years without being used. Now once the oven turns down when the proper temperature is reached, the flame goes out, it cools, then gas comes back on with no ignition, not good. There is a pilot light but it is not lit. It does not appear to be the automatic type, so there is no ''red button'' to hold down. I have found the pilot control valves for the top burners and for the deep-fry well and have them on. There is no similar valve for the oven pilot. How do I turn on the gas and light the pilot lite for the oven?
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Posted on Mar 26, 2009
  • 126 Answers
SOURCE: maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Posted on Jun 25, 2009
johnrodgers1
  • 80 Answers
SOURCE: Gas oven pilot light stays lit OK, but burner will
you thermocouple is weak or flame sensor not in good location
Posted on Feb 06, 2010
heatman101
  • 43501 Answers
SOURCE: My Viking oven will not lite, the igniter glows,
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
Posted on Apr 22, 2011
I put the oven pilot light on and soon i turn the knob it turn off
Not understanding the exact problem here. First off, is this oven old enough to have a standing pilot or is it a glo igniter type? If it's a standing pilot, then you don't put it on, it should be lit all the time. If it's a glo igniter, it will glo, heat up and then turn on the gas when you turn the knob to bake and set the temp. you want to achieve. So, I need a little more info to accurately diagnose the problem. I would like to know the age of the range, and the make and model of the range.
Mar 05, 2014 | Ovens
Where is my pilot light for kenmore 317B6442P001
it shouldnt have a pilot light
there is a hot surface igniter under the pan below the racks
two screws in the back then lift from back (tabs in front)
is the oven not working or lighting?
you cant light with match or lighter
if you are having problems lighting change the igniter
simple to do 15 min get part un piug old plug in new
Nov 18, 2013 | Kenmore Ovens
Have a 1980s model oven model #EH4W4 .My problem is the burners work great but oven does not lite anymore when temp is selected.?
If it is a standing pilot the thermocouple has most likely failed. If it is electronic ignition the the igniter has probably failed. Is the oven plugged in to the wall outlet all the way or is it direct wired? Is it standing pilot or elctronic ignition? Really need more info to correctly diagnose
Mar 11, 2011 | GE Ovens
Our maytag 30-inch wide free standing range is about 4 or 5 years old. We've had no problems since we've had it - until yesterday. The short story is that when I press the "Bake" button, the oven won't...
Hi-  The problem you describe sounds like failure of the igniter for the lower burner. The part can be accessed by removing the drip pan at the bottom of oven. Resistance should be more than 4ohms, but if it doesn't glow at all it is probably broken. The part normally runs 40-75$ and is easy to install. Let me know if this info is helpful, have more if needed. - Thanks- Ed
Mar 16, 2010 | Ovens
Pilot went out on the oven i have an old model # sf315pemw1how do i re-lite? need direction . . .please thanks.
check if ignitor ignites. it should ignite, if its too slow replace it too.
Feb 13, 2010 | Ovens
Kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
Jan 14, 2010 | Ovens
All four burners click at the same time; Sometimes will not light
hey mate i have had this problem with my oven, they get moisture in them. Turn it off at the power point for a few hours or before you go to bed and turn it back on the next morning and it should be fine. that should get the moisture out. hope this helps. Keeno in OZ
Mar 19, 2009 | GE Ovens
Kenmore Gas Oven not working
IT POSSIBLY DOES IF SO IT WOULD BE UNDER TH BOTTOM PAN USUALLY IN THE BOTTOM OF THE OVEN , YOU WILL NEED TO LIGHT IT WITH A MATCH (AFIREPLACE MATCH WORKS BEST ) LET BURN FOR A FEW MINUTES TO MAKE SURE IT GOING TO STAY LIT BEFORE YOU TRY THE OVEN .
Nov 26, 2008 | Ovens
Lighting a pilot light in a 30 year old roper gas range
Lift the top lid and look for a cylinder or something similar with tubing going into it there should be a button of some sort on the side. if you are lucky the button will have a red cap on it. press the button in and light the pilot inside the oven. hold the button for a minute or so until the pilot stays on. kind of like lighting a water heater.
Oct 31, 2007 | Ovens
Ovens Logo
240 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
