Question about TRT MX174S 17" Flat Panel LCD Monitor
Will not come on
Makes a crackling sound in the speakers when plugged in, even when the speaker wire is unplugged from it.  Has a faint flashing in the screen like it wants to come on.  I unplugged everything from pc and left only monitor plugged in, same thing.
The little light by the power button does not come on.  For several months prior to this if you just barely touched the power button it would turn the monitor off or on.
  • ynned Nov 27, 2007
    My trt MX174s 17in. monitor will not come on. When power is applied I get a popping sound through the speaker. Screen stays dark.
  • English47591 Jan 18, 2008
    my lcd will not come on , popping in the speakers when plugged in. i have disconnected from pc completley and tried hooking nothing but the monitor and get the same thing. It is as though it is trying to come on but something is stopping it. any ideas
2 Suggested Answers
SOURCE:
mishra
  • 91 Answers
SOURCE: Monitor Will not come on
remove all the wire from the back side of your CPU like mouse and keyboard.only monitor wire should be connected to the CPU .try this and let me know the status
Posted on Oct 10, 2007
I have a pioneer 2din deck and it sounds bad. it sounds like the speakers are blown and makes a crackling sound. I have replaced the speakers and it still sounds bad. I don't even have a amp
Make sure the positive and negative wires for the speakers are correctly(not reversed) and securely attached to the mounted speakers and the speaker outlet wires on the deck
Jan 16, 2015 | 2000 Ford Ranger SuperCab
Crackling from Creative Tech Gigaworks T40 2 speakers
I do also get this same issue, They were working just fine, and 4 or 5 months ago, the right speaker crackles, if i unplug the right speaker all is fine. But as soon as I plug the right speaker in, i get a cracking sound. Have you solved this ussue?
Oct 28, 2012 | Creative Technology Gigaworks T40 2...
My logitech s-120 speakers crackle very loudly sometimes. At first I thought it was the sound card in my old PC, but when I switched to a brand new Mac computer the problem continued, making me think the...
hi there,
The problem is actually from the speakers themselves. If it's not a year old you might want to bring it back to the store where you purchased it for a warranty repair or replacement.
Sadly the problem is inside the speaker and it could be a loose connection inside. If you're comfortable enough you can try to open the speakers and check inside for any loose wires which cause unstability of sound or for any loosed fittings from the magnet.
Hope this helps!
May 30, 2011 | Logitech S120 2 Speakers
Boston BA790 Subwoofer Making Strange Noises
I just took my sub apart and found that the surround on the driver speaker inside the sub was totally crumbled and lying in pieces throughout the sub box.
I'm looking around now for specs on the sub speaker so I can find a replacement.
Feb 03, 2010 | Boston Acoustics BA790 Computer Speakers
Crackling sound
That sounds like an internal fault on your Bose system.
Leave the Bose unplugged from power and from computer for one hour, to get rid of electrostatic charges accumulated inside capacitors.
If that does not get rid of the problem, then there is an internal fault, either a short on speaker wiring, or a fault on the internal amp circuit board.
May 01, 2009 | Bose Companion 3 Computer Speakers
Car speakers turn on and off randomly and make crackling sound?
The answer is: "Yes." If your speaker wiring is such that they all share a common ground wire, and that ground wire is shorting out, it can cause all speakers to go silent when it is grounded (shorted). I would check the wiring, and replace any cracked wiring, and if the wiring looks like the shielding is worn, replace all the speaker wiring. Monster cable is the best, but any heavy copper wiring works fine. I often use 110V. appliance wiring to install car stereos.
Dec 18, 2007 | Audio Players & Recorders
TRT MX174S 17" Flat Panel LCD Monitor Logo
41 people viewed this question
Top TRT Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a TRT Computer and Internet Expert? Answer questions, earn points and help others
