Question about Ricoh Aficio 2015 Copier
Aficio spc 232dn printer. how to enter service mode
To clear sc 542 error code
boyrevel
  • 71 Answers
SOURCE: sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Posted on Aug 14, 2007
Bubbabear64
  • 2794 Answers
SOURCE: ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Posted on Jul 12, 2008
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
  • 161 Answers
SOURCE: service mode
call service --- possible bad thermistor (fuser)
could over heat
Posted on May 06, 2009
canontech
  • 1219 Answers
SOURCE: i turn on my ricoh aficio 2015 this code SC:542
itS THE TEMPERATURE OR FUSER RELATED ERROR.
try to clear it in service mode
Posted on Jan 13, 2010
WHY RICOH AFICIO MP 171 SPF IS SHOWING SERVICE CALL SC 542.
Reseting SC 543 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Oct 18, 2016 | Ricoh Office Equipment & Supplies
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
Sc 542
enter service mode then mode then reset/clear sc if it came back than change the thermistors
May 01, 2014 | Gestetner DSm745 Black and White Copier
Hi, i have a error code SC 542 but i don't see Yellow Key [clear modes] button on control panel please send me deatil moeen_rauf@yahoo.com
SC 542 Heat roller warm-up error and for that you will need a technician since the machine may need some part replacement .
Feb 15, 2011 | Ricoh Aficio CL7200 Laser Printer
I turn on my ricoh aficio 2015 this code SC:542 apear
Nov 30, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Im having an error sayig SC:542 so how can i solve this kid of problem?
This is a 'fuser" warm up error. You could have a blown out heater lamp, or fuse, but most often this is caused by a power fluctuation. The reset for this is done by simply entering the service mode, and turning the machine of/on with the main power (red button).
enter service mode as follows:
"Clear Modes"
" 1, 0, 7 "
then hold "Clear/Stop" for 2-3 seconds.
The display will change with "service mode" in the top corner.
Now turn power off/ on (red switch)
** Never go further into the service mode, as you can cause all kinds of difficulty.
If the code comes back, then you will have to get a technician on site to troubleshoot the fuser.
Please rate me :)
Apr 24, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Jan 17, 2009 | Ricoh Office Equipment & Supplies
SC542
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Feb 19, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Sc 542 error code
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
