Question about Dryers
Dryer not turning on .
Power verified , don't hear the timer when set , does not turn on
  • ccjet_99 May 09, 2009
    Thanks , it turned out to be the thermal fuse.
  • 1,305 Answers
The power routes first to the door switch.. with the door open, depress the door switch...if there's an interior light it will go off. Then attempt to start the dryer with the button depressed. If it works, then the door needs to be adjusted to shut completely, if not, I would replace the door switch.
good luck let me know how this works for you!
Posted on May 08, 2009
  • KEN LaPOINT
    KEN LaPOINT May 09, 2009
    GLAD IT'S FIXED...WAY TO GO..
Whirlpool gas dryer Model#WGD4900XW1 worked on certain timer settings for 6 mos. Now it only works on one setting and turns off. One more note: you have to gently pull the timer knob for it to turn on
Hello David, We're sorry to hear about your concerns regarding your Dryer. We recommend disconnecting power from the breaker for at least a minute and then turning the breaker back on to do a master reset on the Dryer. If you are in need of help after trying the reset, can you please email us your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 14, 2017 | Whirlpool Dryers
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Kenmore 68731 model 86873100 setting the drying to any of the drying methods, the dial does not move to automatically turn off the dryer.
You have a bad timer motor To verify you will get an ohm meter and remove the wires to the motor.
Check between the motor wires fer continuity. If you have continuity then the next test will verify if the gears are stripped on the motor. Apply power to the timer motor and see if it advances on its own. From looking at your model number I see nothing unusual about the timer.
to get to the[parts list I did 110.36873100. 110 is a the large prefix which ID's the dryer as being a whirlpool model. All kenmores ain't Whirlpool.
Aug 26, 2011 | Kenmore 659 Electric Dryer
The dryer is not going on., no heat, no spin, nothing. This was sudden. I checked the fuses, and then noticed I could hear the timer. I don't really know if the timer is electric.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 06, 2011 | Roper Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer timer will not turn.
Bad timer motor if you are using timed dry.
If using auto dry probably a bad sensor.
Verify by using any time dry or air fluff cycle and see if the timer moves.
Mar 03, 2009 | Kenmore 64902 Electric Dryer
Dryer heats up but won't turn
Depending on the make of dryer,there are several possibile reasons for this.
First and foremost, could be a faulty motor- faulty start capacitor, Faulty start relay.
Without more information I cannot be more specific.
Hope this helps.
Please leave feedback.
Thanks.
Nov 27, 2008 | Dryers
Clothes dryer troubleshooting
my kenmore dryer keeps on drying after the alotted time has expired, i think the timer is the problem. how can i verify and fix this??
teddy
Oct 27, 2007 | Dryers
Dryers Logo
Top Dryers Experts
