Question about Avid Pro Tools Mbox 3 Package (3rd Gen)
"PRO TOOLS" ERROR APPLYING TRANSFORMS VERIFY THAT THE SPECIFIED TRANSFORM PATHS ARE VALID
I have a 2.5oz popcorn machine, I plugged it 220v by mistake and it required 110v, the transformer connected to the motor burned out, is it possible to repair the transformer because I can't find a...
if the switches were turned on for heat and stir functions when wrong power was applied then im sure those functions were damaged as well it's just not apperant right now , are you sure it's a transformer you saw burned ? im not in the knowlege of this unit needing a transformer , could it possibly be a power conditioner thats burned , transformers have iron plates lamanated in many layers that are very noticable from the outside , power conditioners do not have layers or plates but are smooth and covered in metal ??
Jan 17, 2015 | Waring Popcorn Machines Pro Wpm25...
Tip
Measure Tool for transforming image exactly
Have u ever tried the Measure tool which is located under the eye dropper tool. Its really a cool tool to transform a image. Suppose an sccaned image is not straight u can use the measure tool to draw a line on the top of the image slanting area and then goto image Rotate canvas - Arbitary and apply Colock wise or anti clockwise according to the desired side the image should be corrected. Thanks
on Aug 24, 2007 | Adobe Photoshop CS2 for PC
Trying to rename a file in Computer-user-(moms)
Try and download " Long Path Tool " is also useful in situations where you see these error messages: Cannot read from source file or disk, there has been a sharing violation, cannot delete file or folder, the file name you specified is not valid or too long, the source or destination file may be in use and many other file managing errors.
---adamdee
Jul 20, 2012 | Computers & Internet
Cannot Copy File:Data error (cyclic redundancy check).
Try to download" Long Path Tool " is also useful in situations where you see these error messages: Cannot read from source file or disk, there has been a sharing violation, cannot delete file or folder, the file name you specified is not valid or too long, the source or destination file may be in use and many other file managing errors.
Dec 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a Lenovo Y550…before upgrading from Vista (64bit) to Window 7; the Windows upgrade advisor recommended I uninstall OneKey Recovery 6.0 because it wasn’t compatible with windows 7, so I did. After...
I think i know what happened. Windows Upgrade Advisor by the name itself it means that there has to be an older version present on teh system to be UPGRADED. Have you tried installing WIN7 with OKR v6.0 then downloading OKR v7.0 try not uninstalling the OKR v6.0
>I chose not to charge you for rhis since this is more of a suggestion than a resolution... i would like to know what happened after trying this, i would greatly appreciate your comment on this, thanks!
Aug 28, 2010 | Lenovo IdeaPad Y550 Notebook
VB6 error 432 File or Class name not found during automation
The GetObject function requires either a valid file name with a path specification, or the name of a class that is registered with the system. This error has the following cause and solution:
The name specified for file name or class in a call to the GetObject function could not be found.
Check the names and try again. Make sure the name used for the class parameter matches that registered with the system.
Mar 08, 2010 | Computers & Internet
"Error applying transforms. Verify that the specified transform
Run kb404307.exe on affected systems. Important: You should be logged in as an Administrator in order to use this tool.
  1. Download the kb404307.exe utility from the Adobe website.
  2. Double-click kb404307.exe to run it.
May 17, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Installation of Micro Soft Office 2003
If you have a disc may be this progam have experied and you must bye the new version Microsoft Office 2007
Oct 28, 2008 | Microsoft Office Outlook 2003 for PC
When I try to install AdbeRdr812_en_US I receive an error regarding specified transform paths being valid. I am not computer literate enough to know what to do.
From the way you wrote the adobe you are trying to install it looks like it may be a 3rd party download. Just try going to "Free Adobe Reader" which the newest now is 9.0. Look for the red adobe symbol. This site is trustworthy as long as you don't have a redirect in your browser.
Jul 17, 2008 | Computers & Internet
Uninstall nero problem
Better way is to remove it through regcleaner.......
Dec 27, 2007 | FBM Software ZeroSpyware 2004 for PC
Avid Pro Tools Mbox 3 Package (3rd Gen) Logo
75 people viewed this question
Top Avid Computers & Internet Experts
castletech
castletech
JonSnell Electronic
JonSnell Electronic
Are you an Avid Computer and Internet Expert? Answer questions, earn points and help others
