Question about Vacuums
Genie 6 gal. wet/dry vac. sv150q household vac. 1.5 hp/cv. Does this vac need a filter? It blows back small particules out the top.....Thanks for your help, Frustrated
SOURCE: USE GENIE WET DRY VAC WITH OR WITHOUT PAPER LINER?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The PB15 uses a fairly large pleaded paper filter for dry use, but it is an odd ball, as most of these type filters are held in place bay some sort of plate, and plastic nut. The PB15 uses a filter that has a bottom, and is pressed into place. For wet use, I would see if you can use the foam filter for one of the Craftsman small W/D vacs, like the old 2 gallon model, held in place with a rubber band, which is slipped over the cage with the float ball. It needs to be sealed across the bottom. That should cut down on spray making its way to the motor. The PB15 does have one good feature as the vacuum inlet has an elbow which keeps the water from being sucked straight into the motor intake, so the foam filter should do the job pretty well. I’d also look at the bag and rubber band that is used on some of the smaller Craftsman vacs, which sounds like what has been done on yours already. They are easy to find.
Because Genie no longer makes any vacuums or blowers, and did not keep a parts inventory to support owners of their products (a reason not to buy one of their garage door openers) it might be best in the long run to ‘garage sale’ the Genie, and buy a new vac from a brand that will be around for awhile. I have two Craftsmen, and one Ridgid, besides the PB15, which is going in the nest garage sale, for the above reason.
As far as your blower to vacuum problem -- The hose is moved from the blower outlet, which is the top black piece with the handle and switch, to the hole in the canister for vacuum. The intent of the PB15 was to use the top piece as a hand held electric leaf blower, or when attached to the yellow canister as a vacuum, when you use the hose attached to the canister.
Posted on May 06, 2009
  • 11 Answers
SOURCE: jhe4576. I own a Genie SV125Q, 5 gallon wet/dry
Where did you buy this unit from? Go back there and ask if they have filters for yours. Otherwise look in the Yellow Pages for vacume cleaner repair shops. Sometimes they have all kinds of filters for all kinds of vacumes. You can try places like Wal Mart. What you want to look for are filters that will work with your unit. The foam filter you refer to is called a pre-filter. It traps the bigger particles so they won't damage your paper filter or clog it up especially if it's wet stuff you're picking up. You can remove that foam filter and gently wash it out in the sink with a mild dishwashing liquid and warm water. And even sometimes if you have time you can wash a paper filter out by hosing it out from the inside, with just a gently rinsing on the outside. Don't use any solvents on it just soap and water. And don't use high pressure either, as it will destroy the paper. I have cleaned my paper filters several times before I finally had to replace them. You can also look at places like Lowe's. They carry shop vacs and a whole assortment of attachments as well.
Posted on Mar 08, 2010
ftw1952
  • 10319 Answers
SOURCE: Where can I fet parts for a Genie SV300Q wet/dry
Depending on what parts are needed Home Depot for instance carries parts for these
Posted on Apr 13, 2010
SOURCE: how to set up wet dry vac for water pick up
you take the filter off and empty it.
Posted on May 01, 2010
javeedcare
  • 316 Answers
SOURCE: I have an old shop
http://www.hammerwall.com/Download_Manual/16114/
GO TO THE ABOVE ADDRESS TO GET YOUR MANUAL.
REGARDS.
PLZ RATE THIS
Posted on Jul 04, 2011
Where do i place the foam sleeve for 5 gal craftsman wet vac
The foam just is put over the round center beneath the top of vacumn with top off the bucket. Just slide up to top of round assembly and you good to go. If you have the paper bag filter on remove it first.
Aug 31, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
Where can I find a filter for genie sv300q?
I have the Genie 3000 which is a 20 gal. wet/dry vac with a 3.0 HP motor. I had bought at Home Depot some 20+ years ago. I bought a replacement filter at HD made by someone other than Genie and claiming to fit my model...but it did not fit...too loose to stay in place. I did track down some hypo filters that might fit...but at $28+ for the filter I decided it was time to get a new model with better and cheaper and available filters. I bought a Ridgid WD1451 14 gal with 6.0 HP. It is so much nicer and quieter. HD regularly carries the WD1450 for $99 or so. The WD1451 is the same model but also had the car vac hose and attachments (a $40 set) included for free. That was a limited offer probably no longer available. Get you a new one and enjoy it...I did...and I still have the Genie...but I think I'll toss it because it is too big, too loud, and I love this new Ridgid.
May 28, 2014 | Genie Company GV150 Wet/Dry Vacuum
Genie 400PC 16 gal shop vac but can't find filters
If you need paper filters, you can easily use a bag filter cut in half, and have less dust clouds than the original filter. Remember to use the lock ring. Generic ShopVac mini's have the same filter in foam.
Mar 11, 2010 | Genie Company GV150 Wet/Dry Vacuum
Apr 16, 2009 | Genie Company GV150 Wet/Dry Vacuum
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Mar 23, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Genie Wet/Dry Vacuum replacement part
Hi, you can find genie replacement parts on amazon, click here and take a look: WORKSHOP Vacs Suck It Up Get It Done. I hope this was helpful. Cheers
Feb 17, 2008 | Genie Company GV150 Wet/Dry Vacuum
Vacuums Logo
267 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
