Will not fill with water and starts washing cycle
It acts like it is full of water.
  • Washing Mach... Master
  • 8,220 Answers
Might be sand in the botton of the tub blocking the pressure switch hose. Remove the hose and blow through it to clear the hose and pump the remaing water out (if any) and retry.
Posted on May 08, 2009
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
Doesn't fill
Possible that the water level sensor is faulty as it tends to indicate before the level has reached thereby starting the rinse cycle.
Usually this can be due to faulty level settings or fault in the pressure switch as it can be acting too fast. It will be best to clean the inlet valve and check the flow , test the water level sensor and see if this works by blowing into the diaphragm.
Sep 04, 2012 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Fill cycle stops before full
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 03, 2010 | Kenmore Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Hi i have an incognito built in dishwasher. it is
It is a PC board issue. Good thing you bought the warranty, hopefull it covers labor and not just parts.
Aug 26, 2009 | Miele Dishwashers
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine stuck in fill cycle
It certainly sounds like the water level switch acting up. Do a couple of other checks first. Make sure you are not siphoning on the initial fill. Check your drain hose and make sure there is an air gap to the drain pipe. If you don't have a gap sometimes it will fill and siphon right out. Next would be to examine the level switch hose that runs to the tub. You want to make sure that there is no pin hole leaks in it causing this problem. Once you are satisfied the drain and tubing is ok, get another piece of tubing the same size and blow into the level switch when the machine is acting up. If the water stops, you can be almost certain it is the switch. Part number...3366847. It's important to do these checks because I have seen timers on this model mimic the water level switch. Catriver..post back.
Oct 16, 2006 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
