"xerox 7232" "service manual" - Office Equipment & Supplies
5 Suggested Answers
  • 64 Answers
SOURCE: xerox 7232 workcentere cannot send emails
Judging from what you've said, I would say this is a setting on the printer. You need to make sure you have the outgoing address correct. Basically go into your printer settings with your E-mail server IP's.
Posted on Jul 17, 2009
SOURCE: Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Posted on Sep 17, 2009
duane_wong
  • 6826 Answers
SOURCE: The Windows 7 mini drivers for the Xerox 7132 only
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=WC7132&ripId=&Xtype=download
The above is the XP Vista drivers for the 7132.
The 7232 is a totally different machine and the windows 7 drivers for it will not work with your 7131 according to their table.
Also, according to Xerox's table, windows 7 drivers are definitely not available for the 7132. The latest drivers are for Vista, but that's not necessarily a bad thing, because windows 7 can run vista programs in its compatibility mode, or many times it works alright after downloading and installing the vista drivers.
Hope this helps!
Posted on Jul 14, 2010
lbrown1806
  • 488 Answers
SOURCE: I need a list of erro codes and definations for
When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
003-754
003-755 An error occurred in the document scanner. Reset the document, and scan again.
003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
smaller segments.
003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
005-210
005-275
005-280
005-283
005-284
005-285
005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
Posted on Jan 16, 2011
XEROX 7232 YELLOW HOW TO REPLACE
go to machine status> supllies select the color u want to replace let is spin and then open the door n pull out old toner input new toner
Dec 16, 2014 | Xerox WorkCentre 7132 7232 7242 Yellow...
How can i resolve error 010-333 for xerox 7232
Fuser unit change problem continue nvm change 744-004 change value 0
Feb 09, 2014 | Xerox WorkCentre 7232 VSE All-In-One Laser...
I need to know if the Transfer Belt Unit for the XEROX 7232 (newer model) PN 064K92790/1 can be used in the 7132 (older model) instead of the # 064K92402/4. I have one and would really not have to purchase...
What you have is a 7232 IBT belt assembly. The internal workings of the assembly work with the 7232 and 7242, but not the 7132 - they are different model series.
Aug 28, 2009 | Xerox Office Equipment & Supplies
23 people viewed this question
k24674
jasbo
jasbo
