Question about T005.740.002 Chrome Copeland Thermostatic Valve
ON COPELAND D8SJ1-6000 BWM/D.THERE IS RESISTANCE BETWEEN ALL WINDINGS IS IT CORRECT AND WHAT THE RESISTANCE SHOULD BE.THANKS
What is the resistance of the primary winding?
Hi I just checked the primary winding on two transformers for u one was 13 ohm the other 21 ohm for 240 volt power supply Sounds like u have a shorted turn on the primary winding. Hope this helps
Dec 09, 2015 | Yamaha RX-V2700 Receiver
Kipor KDE6500T3: no voltage after overload caused by music system
There is still much you need to check. Is the magnet broken, when you say windings have resistance, how much restance? Did you check all connections an clean them? Are the diodes working? Did you measure any voltage at the input of the diode pack? If so is it very low or excessively high? Are you sure no voltage is coming after the diode pack? It could be a short in the windings. Do you have the wires connected correctly? Just way to much to ask an need a bunch more info on what you are finding an doing.
After looking at the service manual did you check the exciter or sampling coil? Have you checked the brushes? Have you checked he current transformer? Also is the breaker pushed over correctly? I had this happen once. It could be bad. To many things to check.
Aug 05, 2015 | Cars & Trucks
How to check for spark, harley springer
Ignition Coil Primary Circuit Test
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is 0.5-0.7 ohms. If primary resistance is not within this range check out test results below.
Ignition Coil Secondary Circuit Test
With the ignition coil removed from the motorcycle and the ohmmeter set to the RX1K scale place the ohmmeter leads on the secondary coil windings B (middle terminal) to
R (rear secondary terminal/socket), B to F (front secondary terminal/socket) and check for secondary coil winding resistance which normal resistance range will be 5.5-7.5K ohms. If secondary resistance is not within this range check out test results below.
Test Results
A low resistance value indicates a short in the coil winding which requires coil replacement.
A high resistance value might indicate that there is some corrosion/oxidation of the coil terminals requiring the coil terminals to be cleaned and the resistance test then repeated and if after the test is repeated the resistance is still high after the terminals were cleaned the coil must be replaced.
If there is an infinite ohms or no continuity) resistance value the coil is open and must be replaced.
May 03, 2014 | 2003 Harley Davidson FLSTS Heritage...
Problem code 32
Hi there:
This fault code is pointing to a fault in the Driver's Side Air Bag module. To correctly diagnose this issue, you will need to run several tests on the components of this system.
Driver air bag high resistance can be caused by:
  • - a poor connection or corrosion in the driver air bag module circuits or the air bag sliding contact.
  • - an open circuit or high resistance in the air bag sliding contact windings.
  • - an open circuit or high resistance in the wiring harness.
  • - an open circuit or high resistance in the driver air bag module.
  • - an RCM internal concern.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 18, 2012 | 2001 Ford Escort ZX2
Refigerator is not getting cold enough, about 46 to 47 degrees the freezer is working fine. The fan is not working, so I hooked up a fan and is helping some but not enough, what can I do. Thank...
Is this a Dometic unit? I really need a good model number if this is not a Dometic unit because the Dometic unit RM2852 does NOT have any fans at all.
If I am understanding this correctly your condenser fan is not operating. Do a resistance check on the fan winding. (POWER Removed) If you get resistance clean up the fan motor as best you can and lubricate the bearings with a paraffin base oil like Zoom Spout Turbine Oil or Union 76 Turbine Oil. (Thanks for choosing FixYa,
Kelly
Aug 03, 2011 | Dometic RM2852 Refrigerator
I have power to the HEI distributor, but nothing down the plug wires. I would like a test to see if the internal(removable) coil is good, maybe a resistance value
Below is a generic proceedure for checking your ignition coil.
Ignition Coil Resistance
  • With the key off and the battery lead to the ignition coil disconnected, use an ohmmeter to measure the primary and secondary winding resistance of the ignition coil. when checking the resistance across the windings, pay particular attention to the meter reading. if the reading is out of specifications, even if it is only slightly out, the coil or coil assembly should be replaced.
  • To check the primary windings, calibrate an ohmmeter on the X1 scale and connect the meter leads to the primary coil terminals to test the winding.
f22-39.gif Ohmmeter connected to primary coil terminals.
  • An infinite ohmmeter reading indicates an open winding. The winding is shorted if the meter reading is below the specified resistance. Most primary windings have a resistance of 0.5 to 2 ohms, but the exact manufacturer's specifications must be compared to the meter readings.
  • To check the secondary winding, calibrate the meter on the X1,000 scale and connect it from the coil's secondary terminal to one of the primary terminals.
Oct 30, 2009 | Chevrolet Impala Cars & Trucks
Manitowoc QY1304A Ice Machine Compressor will not start
Does the compressor make any noise at all?
You can ohm out the compressor windings. I dont know off the top of my head which compressor manufacturer they are using but if it is Copeland you can get an electrical handbook and it will have ohm values for the compressor. If not assume the rule of thumb Common to Run is X, Common to Start is Y, Start to Run is X+Y, and Y should be 3 to 5 times whatever X is. On Rx10,000 scale check each terminal to ground should be open.
Aug 06, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
P1370 and p1350 trouble codes
P1370 Ignition Control (IC) Module 4x Reference too many pulses
P1350 Ignition Control System
Ok, these codes are signaling a malfunction within the Ignition control module. it is sending way to many signals to the coil. i recommend testing the coil for damage and irregular resistance. i will explain how to do this below. i would replace the module as well. The control moduel is Located Under hood, center, rear engine area, above valve cover, mounted in base of ignition coil pack
Ignition Coil Test Procedures__
* with the key off and the battery lead to the ignition coil disconnected, use an Ohmmeter to measure the primary and secondary winding resistance of the ignition coil. when checking the resistance across the windings, pay particular attention to the meter reading. if the reading is out of specifications, even if it is only slightly out, the coil or coil assembly should be replaced.
* To check the primary windings, calibrate an ohmmeter on the X1 scale and connect the meter leads to the primary coil terminals to test the winding.
* An infinite ohmmeter reading indicates an open winding. The winding is shorted if the meter reading is below the specified resistance. Most primary windings have a resistance of 0.5 to 2 ohms, but the exact manufacturer's specifications must be compared to the meter readings.
* To check the secondary winding, calibrate the meter on the X1,000 scale and connect it from the coil's secondary terminal to one of the primary terminals.
# A meter reading below the specified resistance indicates a shorted secondary winding. An infinite meter reading proves that the winding is open.
# In some coils, the secondary winding is connected from the secondary terminal to the coil frame. When the secondary winding is tested in these coils, the ohmmeter must be connected from the secondary coil terminal to the coil frame or to the ground wire terminal extending from the coil frame. Many secondary windings have 8,000 to 20,000 ohms resistance, but the meter readings must be compared to the manufacturer's specifications. The ohmmeter tests do not indicate such defects as defective insulation around the coil windings, which causes high-voltage leaks.
May 17, 2009 | 1997 Cadillac DeVille
Copleland scroll compressor failure
I have scroll chiller contains scroll compressor tandom circuit. One of the compressor failure from it due to unbalance of the winding. Previously compressor thermistor opens two to three times. Also one phase open in contactor of the compressor. Can you guide me regarding the reason of compressor failure and what is the next step for the replacement of compressor. Also give guide line for the points take care.
Nov 02, 2008 | Goodman Heating & Cooling
T005.740.002 Chrome Copeland Thermostatic Valve Logo
81 people viewed this question
Top American Standard Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an American Standard Vehicle Part and Accessory Expert? Answer questions, earn points and help others
