Question about Dymo LabelWriter 400 Thermal Printer
I'm having problems with my Labelwriter Twin Turbo. When I try to print a label the windows spooler comes up and the label never prints until I reboot or shutdown. When the computer starts back up the label prints. I can only print one label at a time with a reboot or shutdown between each one. Any ideas?
  • 2 more comments
  • Bryan Johns May 09, 2009
    I tried installing the latest driver from DYMO's web site. The driver install doesn't even detect the printer. I've tried different USB cables. I think I'm gunna call DYMO support directly as soon as I can actually be at home during their operating hours.
    Luckily my printer is pre September 2007 so doesn't fall within the range of printers with recalled power supplies.
    I wish I could identify exactly when the problem started. I think it was farther back that my restore points go unfortunately.
  • solderfix May 11, 2010
    Just FYI: Note there is a safety recall for this label printer.  You should check the following link and get a replacement power supply to avoid a possible burn hazard:
    http://global.dymo.com/enUS/CampaignsHom...
    Scholar:
  • 55 Answers
If you go to control panel printers and then right click on your printer and select properties, you might be able to turn off the spooling.  It should be under the Advanced tab.  Click "print directly to the printer".
The other option is to try installing an updated printer driver, but you may still need to do the procedure above:
The following link may not work: Click here
Paste the following link into your web browser if the link above doesn't work:
https://global.dymo.com:443/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Posted on May 09, 2009
  • solderfix May 09, 2009
    If you are running Windows Vista, you can try backing up to a restore point where you were running the old driver that presumably worked, then check the "print directly to the printer" in the printer properties.
    If you are running XP, have you tried uninstalling the software and then reinstalling it?
Dymo LabelWriter 450 Twin Turbo - Until recently worked fine from both sides. Suddenly, no longer printing from left - prints half a label, then stops, then error message says Out of Paper, the blue light...
See if it still happens using a fresh label roll. From the Dymo 450 User Guide the common causes of poor print quality issues.
Poor print quality is most frequently caused by one of the following:
• An old roll of labels
• Labels made by a manufacturer other than DYMO
• Labels where the thermal coating has been compromised
• A dirty print head
First, make sure you are using DYMO-branded labels. Do not use third-party labels because the thermal coating on other labels has a different sensitivity than DYMO-branded labels. Also, the perforated holes between the labels made by other manufacturers are frequently not detectable by LabelWriter printers.
If the print quality becomes faint, small dots of white appear scattered through the printed characters, or light and dark patches of printing appear, you are probably using a faulty roll of labels. Try using a different roll from a fresh box. If the second roll prints correctly, the problem is with the first roll of labels.
Another possibility is that the LabelWriter print head needs cleaning. Every LabelWriter printer comes with a cleaning card. See "Caring for Your Printer" on page 17 for information about the
LabelWriter cleaning card.
Sep 13, 2013 | Dymo LabelWriter 400 Turbo Thermal Printer
When adding the Dymo labelwriter 450 turbo to Windows 7 machines, the installation completes fine. When attempting to print, an error shows up in the device manager that says Access Denied for the print...
i HAVE LABEL WRITER 450 TWIN TURBO AND I CAN NOT PRINT RETURN ADDRESS LABELS. i HAVE UNINSTALLED AND INSTALLED AGAIN THAT DOESN'T WORK THE RETURN ADDRESS LABEL IS THERE IT WON'T LET ME TYPE ANYTHING IN THE SPACE PROVIDED IT WAS WORKING FINE THEN THE NEXT DAY IT WAS NOT
THANK YOU
Aug 19, 2011 | Dymo LabelWriter Thermal Printer
My Dymo Labelwriter Twin Turbo will not print from stamps.com, nor will it print regular mailing labels
Kathy,
Stamps.com supports this thermal printer. If you would like assistance, can you please email me at social(at)stamps.com?
Thanks!
Chuck
Stamps.com
Sep 27, 2010 | Dymo LabelWriter Thermal Printer
OUR DYMO LABELWRITER TWIN TURBO JUST STOPPED PRINTING--
OK! The first time you tried to print ON THE LEFT SIDE, without anymore labels there, there was a "pending" error message in the print queue. This typically cuts off all furtther printing, as all subsequent requests are "behind" it in order or priority.
To fix this, open the Dymo Labelwriter "Printer" dialog box (double-click it on the tray or go to "start / control panel / printer and faxes" - then double-click on "DYMO LabelWriter Twin Turbo". Once open, you'll see a list of "failed" print requests. Somewhere in there you'll find the one with the "laserwriter output" out of paper message. Select that and cancel or delete it.
If this was the problem, all your attempts will now print (make sure you have enough postage paper in, and you'll have extras you can use, I'm sure!
Hope this helps.
Jun 17, 2009 | Dymo LabelWriter Thermal Printer
Not printing
I have installed the Dymo LabelWriter Twin Turbo and it iwll not print my labels. Any suggestions?
Aug 15, 2008 | Dymo LetraTAG Thermal Label Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo Twin Turbo Labelwriter not printing stamps
This is the response from dymo stamp. I did as they said and am now printing stamps again.
We have seen this cause problems with the .NET framework Microsoft uses and Dymo Stamp uses. Follow these steps to correct it Step 1: Download Microsoft Windows Installer CleanUp Utility
1. Visit:
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
2. Save the file on the Desktop.
3. Please double click the msicuu2.exe file to install it on the computer.
Step 2: Remove .NET Framework
1. Click Start -> (All) Programs->Windows Installer Clean Up.
2. Please locate and remove Any .NET Framework 2.0 software.
After that, please perform the following suggestions to reinstall .NET
Framework 2.0 and its updates. Step 3: Reinstall .NET Framework Version 2.0 SP 1
Please download and install the following
Microsoft .NET Framework 2.0 Service Pack 1 (x86
http://download.microsoft.com/download/0/8/c/08c19fa4-4c4f-4ffb-9d6c-150906578c9e/NetFx20SP1_x86.exe
Note: When the "File Download" window appears, please click Save, and follow
the directions to save the file on the Desktop. After downloading all the
setup files, please double-click on each one to install them.
Apr 15, 2008 | Dymo LabelWriter Thermal Printer
Consistantly Intermittent Connection Problems
If you've tried installing the latest drivers and the problem persists it sounds like you have a lemon. The printers have a 2 yr warranty, so I would contact the retailer you purchased from and replace the printer. If your labels are jamming. Try the compatible File Labels available at LabelValue.com. They have both the Dymo 30327 and Dymo 30277 labels in a compatible version.
Feb 29, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo LabelWriter 400 Thermal Printer Logo
328 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
