Question about Euro-Pro Shark 60 - 384
Zigzag stitch pulling tight, looks wrong
I am trying to applique with my Brother Pacesetter 200 using the zigzag stitch. The problem does not seem to be limited to the zigzag stitch. On the zigzag, the back looks great, but the front has the thread pulled to one side. I've tried adjusting the presser foot and thread tensions, but it doesn't help. Any ideas? I'm having the same problem with my Euro-Pro Shark.  No matter how I adjust the upper thread tension, I have the same problem, although if I hold the tension completely open the top comes out fine and the bottom is full of knots and extra thread from the bobbin.
    Problem Solver:
  • 13 Answers
Try adusting the bobbin thread instead of the top. Always make sure to insert the bobbin so the thread is pulling in a clock wise direction. Both threads top and bobbin should have about the same resitance when pulled.
Posted on May 27, 2009
  • hodgen56 May 27, 2009
How can I use my Bernina 640 Artista to applique
Perhaps I'm not understanding your question. When doing applique, I use a very tight zigzag stitch with a satin stitch foot or open-toe embroidery foot (so the thickness of the stitches do not create buildup under the presser foot). Set the tension so the bobbin thread stays mostly under the fabric so the top thread is the only thread that shows on the top (sometimes threading the bobbin pigtail will help).
Fuse the cutout fabric to the backing fabric. Then zigzag so the raw edge of the fabric is covered by the zigzag (helps to use a thicker thread so the coverage is easier).
Some newer machines have the ability to miter corners. On my 930, I set the needle position to the outside of the raw edged. Then when I near the corner, I gently, but consistently, narrow the stitch width to an an outside point, since the needle on the outside edge, turn the fabric and gently, but consistently, widen the stitch to full width. This creates a nice mitered corner.
When making curves, stitch small lengths and then sink the needle on the outside of the curve, and gently turn the fabric to follow the curve and repeat while going around the curve.
https://books.google.com/books?id=MQneD8cQ5KAC&pg=PA13&lpg=PA13&dq=mitered+applique+corner&source=bl&ots=1sHsUrkVAz&sig=1WZ-i2-T3RtvUEW797sHxTKiq4E&hl=en&sa=X&ved=0ahUKEwiaoZeiwunKAhVslYMKHewdDFEQ6AEIKzAC#v=onepage&q=mitered%20applique%20corner&f=false
How to Appliqu Like Pro Sew4Home (FWIW, IMHO, the satin stitch on the bird is really a poor example. The stitch is not very even at all--could be the sewing machine.)
How to Make and Apply Appliques (The giraffe is a better example, although choosing a simple design to applique usually yields better results.)
Practice, practice, practice!
Feb 08, 2016 | Bernina Artista 640E Sewing, Quilting and...
Not stitch zigzag
Have you tried a needle change? It could be blunt or the wrong size. Have you cleaned under the needle plate as the ridges get full of lint there. A toothpick will clean them out.
Nov 22, 2013 | Singer 1120 Mechanical Sewing Machine
Zigzag stitch not catching
try these suggestions and see if they help
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Oct 19, 2012 | Brother CS6000i Computerized Sewing...
My white rotary model 2221 sewing machine will no longer switch from straight to decorative or zigzag stitching. What can I do to fix it? I have cleaned and oiled the machine and have recently used it...
it's possible that the cams that do the zigzag stitch could be worn or have gotten damaged
it would be a good idea to have it serviced
I would suggest to look in the yellow pages & see what sewing machine repair shop are in your area.
and if you do get it serviced, when you first get it home, sew on it & make sure it works correctly, they normally have a 15 to 30 day time limit for you to check the machine out & making sure it works ok, & make sure that you don't just pay for a cleaning..
Sep 11, 2011 | White Sewing Sewing Machines
I want a loose button-hole type of stitch to do my first applique by machine. I have put the needle to one side, put on foot #20 -- and now what stitch?
This depends entirely on your model of machine and the kinds of stitches it is designed to make. Not all machines will make the kind of stitch you describe. My machine has a buttonhole stitch, but with slanted bars, and it really doesn't give the right look.
Check your machine manual and look for a stitch that gives you the look you want--you might have a "blanket stitch" option. If your machine doesn't offer a buttonhole or blanket stitch that gives you the look you want, you may want do use a narrow zigzag satin-stitch. You can also do a straight stitch very close to the raw edge of a fused applique but it won't look as tidy.
Apr 01, 2011 | Sewing Machines
Stitches not catching with zigzag stich only one side catches.
how do you adjust the tension on the bobbin?
May 02, 2010 | Brother CS-6000
How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Jul 09, 2008 | Brother LS-2125 Mechanical Sewing Machine
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Mar 07, 2008 | White Sewing 1418 Mechanical Sewing...
Euro-Pro Shark 60 - 384 Logo
715 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
