Question about Garden
I HAVE A FORD 1220 COMPACT DISEL TRACTOR TRANSMISSION SLIPS
I HAVE A FORD 1220 COMPACT DISEL TRACTOR HYDOSTAT TRANSMISSION WHEN ITS COLD IT WORKS FINE BUT WHEN IT WARMS UP THE TRANSMISSION SLIPS WHAT COULD BE THE PROBLEM
  • ROGECJR May 10, 2009
    NOT YET IS THERE A PLACE I CAN CHECK HYDRO PUMP PRESSURES. ALSO WHAT DO YOU MEAN CHARGE THE FLUIDS. IS THAT LIKE ADD HYDRO FLUID. I CHECKED IT AND IT WAS FINE
  • ROGECJR May 12, 2009
    thanks john, iwas looking for the pump # and i seen the radiator and the oil cooler for the hydro was pretty well pluged up. so i thought it was making the hydro oil too hot and that was why i was loosing pressure. so i took it all apart and cleaned both the radiator and the oil cooler. after i got it back together i tryed it and it seems to be fine. thanks for the help. but for fyi it would be alot cheaper to check the oil cooer first before going for the pump. thanks for headinf me in the right direction. carl
  • 246 Answers
Hello:
It is Possible the Fluid Requires Changing or the Internal Pressure Pump is Worn and when the Hydro Heats up the Pump Loses Pressure.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • John C Bridgers Sr May 11, 2009
    Hello:
    Since you have Checked the Fluid Level and it was Good, then the Internal Pump is Bad and Loosing Pressure when the Unit Gets Hot. Replacing the Hydro is the Only Option you Really have here. The Transaxle OEMs Never Suggest Repairing a Hydro Unless you are Certified and have the Proper Tools and Equipment for Testing.
    Send me the Make and Model Numbers of the Hydro Off the Tag on the Hydro.
    With these Numbers I can Locate the Correct Manual and Better Assist you.
    Hope this Helps. Let me Know What Happens, Please. As Always, May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
    Good Luck
    Respectfully
    jbridger (John)
  • John C Bridgers Sr May 12, 2009
    Hello Again ROGECJR:
    You are Welcome. I will Add the Cooler to My List of Possible Causes for this Problem on All Hydro Transaxles. Thanks for the Feedback.
    >>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
    Best Wishes and Good Luck
    Respectfully
    jbridger (John)
Cylinder head for ford compact 1700 tractor FO 1.3 lt Shibaura LE8
Japanese made ...1979 - 1982 Hundred Compact Series...
going to be very tough find that two cyl head
try this ford compact 1700 USA supplier
https://www.almatractor.com/parts/ford1700tractorparts.htm
any chance to a retro fit a different engine same series
Ford 1700 engine
TractorData com Ford 1700 tractor information
Oct 18, 2016 | Ford Cars & Trucks
On a case 580k 4x4 backhoe is 4th gear set up different then 1st 2nd 3rd tractor won't move in lower gears made no noises or grinding .
Hi Bill:
I'd check with my local Case dealer. We have several pieces of Case equipment with hydostatic drives.
If I remember correctly, high gear on a standard transmission is a 1:1 ratio in that the power is on a straight through shaft.
My suspicion would be that a shifter link ay have become dis-connected.
Here's a link that may assist.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=1987+case+backhoe+580k+4x4+transmission+diagram
Cheers
Apr 04, 2016 | Cars & Trucks
2002 chrysler 3.5 transmission slips when warm shifts fine when cold
change the transmission filter and put lucas transmission treatment
Nov 12, 2013 | 2003 Chrysler Concorde
My craftsman tractor will only mow for about 10-15 minutes then won't move.the transmission oil is okay and it is hydroststic driven
In my dealings with hydostat drives, the forward-reverse valve is bad or the pump itself. When it is cool the hydraulic oil is thicker but thins as it heats up, letting it get passed the bad seal(s) causing low pressure!
Aug 28, 2013 | Craftsman Garden
New tractor power loss on a grade, deos not develop full speed
Hello Joe
If you have an automatic or hydrostatic transmission then you have a lemon, which means once the oil heats up in your transmission it thins out and clutchs and swash plate have no grip on the drive system which is hydraulic pressure needed to hold on the shaft and axles this happens all inside the transmission you cant see it but you can tell when going up slight hills and when you have the blades engaged it crawls like a turtle get you warranty out Joe..... dont touch anything that may void your warranty..... just call service department they will send service man out to your home even after that keep a good eye on your tractor since its still under waranty for further problems.
Joe your 20 year old craftsman had a better built ****** by sears and you probably had a 6 speed or five speed even hydostatics were good too,they dont have much problems except belt slipping its an easy fix this new tractor u need service man right away.
Joe
Oct 08, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Slipping transaxle, '97 Ford Taurus
men you need to have a tune up, change the plugs, wires and air filter and the oil transmission, and if is doing the same your transmission is bad
Mar 07, 2009 | 1997 Ford Taurus
1998 ford ranger 3.0 motor auto.transmission slips driven cold
what is the (revolutions per minute) rpm of your engine when the torque converter engages, was the torque converter rebuilt too? what type torque converter is in the ford ie low stall where it engages the gear box at around 900 to 1000 rpm. has there been any power band adjustment by the company that rebuilt your automatic transmission after the insallation.
Jan 02, 2009 | 1998 Ford Ranger SuperCab
Garden Logo
551 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
