Question about Air Conditioning and Heat for Hyundai Azera
How to fix the trap door in dash for heat/cooling
Ice through trap door
To prevent this problem of ice formation, you need to maintain a fix time interval of switching on and off your refrigerator unit. It will help in maintaining cooling as well as ice level.
Jan 02, 2014 | LG LFX25960ST Stainless Steel French Door...
2004 Toyota tacoma Pre runner 4 door AC works fine blows cold, No heat ? have checked radiator and thermostat as well as heater core have hot coolant running through entire system but still no heat not on...
You have a problem wit the air temperature control blend or the blend door actuator motor, most times both are defective. The parts are located deep in the dash and as such the dash assembly must be removed to service the parts.
Jun 26, 2017 | 2004 Toyota Tacoma
04 safari trying to find the door that turns to switch cool to hot its stuck very little heat comes out
The trap is under the dash in the lower right hand corner of the dsh. It may not be the trap, it may be the switch, a brolen cable or a vacuum leak.
Jan 23, 2013 | 2004 GMC Safari
Has no heat engine temp good heater hoses hot
U have a failed air temperature control electric blend door actuator, to replace this part requires the dash be removed from the car, the part is located on the outside of the heating duct about center of dash.
Feb 26, 2010 | 1997 Lincoln Town Car
The temp. goes up but the van has no heat coming out of the vents
the lever on the side of the matrix turns the heat on and off try it its behind the dash in the middle next to your feet
Dec 15, 2009 | 1999 Oldsmobile Silhouette
When puting heater on cool browing hot air
There is a door attached to the cable behind the levers on the heater controls. The cable goes to the heating unit under the dash to a trap door that is supposed to move. You will want to look to see that the cable is attached and moving the lever on the side of the blower box under the dash. If its not moving, move it manually and see if you get temperature change to cool. Probably, your heater is stuck on and hot air is being carried over the heater core and into the vehicle. You need to close off the door that allows the heat into the vehicle and then trace the cable back to the lever to find out where the problem is. Maybe a broken or disconnected cable or improper closing heater box door.
Aug 15, 2009 | 1988 Ford Festiva
Heater not working, blower not putting out hot air.
its going to be your heater core which is located on the passenger side under the dash board. pretty $$$ . its cheaper if you know someone who could do it 4 u
Jan 01, 2009 | 1997 Chevrolet Malibu
Heating problems
This problem is caused by a defective blend door (stuck) or blend door actuator motor. The blend door is what moves in the air stream to supply heat or cool, or a blend of the two, it is in the dash and the dash must be removed to access it for repair.
Oct 22, 2008 | 2004 Ford Explorer
Heat & air conditioning
your ac/heater door controler motor is not working it opens and closes the trap door in the dash it is right behind the dash it cost around 140.00
Jun 14, 2008 | 1999 Ford Expedition
Air Conditioning and Heat for Hyundai Azera Logo
41 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
