Question about Air Conditioning and Heat for Hyundai Azera
Dual climate control blowing hot air only on driver side
2 Suggested Answers
sxygaman
  • 95 Answers
SOURCE: 2008 azera with dual a/c blowing hot air only on drivers side
trap door in dash closed not letting cold air pass across
Posted on Aug 12, 2012
Why does 1 side of dash blow hot and the other cold when ac is on with the dual climate control?
Check the actuator motor on the heater it directs the air into the vents. There is probably two of them be sure to check both. The motor makes the vents move and again directs the air where you want. Hope this helps.
Aug 01, 2016 | 2005 Ford Freestar
2003 chevy trailblazer blows cold air on passenger side and hot air on driver side
Sounds like a blend door actuator failure,11_24_2012_3_52_06_am.jpgMight as well replace both sides
Nov 24, 2012 | Cars & Trucks
My AC blows hot air out the driver's side and cold
My 02 Century has dual temp controls . One for driver for passenger. Make sure you don't have the dual climate enabled and just set for heat on your side and AC on the passengers
Apr 04, 2010 | 2001 Buick LeSabre
Air conditiom blows hot air on passanger side
yur air handler could be bad on that side or if you have dual climate control the control for that side could be bad.
Mar 26, 2010 | 2000 Lincoln LS
No hot air on driver side. Pasenger side has hot air.
if it has dual zone climate setting it could be stuck in the cool setting. if it is not blowing any air it could be the duct came loose and it is blowing the air inside the dashboard. it will require you to pull the dash apart to inspect what the exact cause is. it could be anything from a bad temp setting switch in the climate control panel to a bad vac line that that switches the air from hot to cold. any other info you could give me may help such as if it is full electronic climate or manual knobs, dual zone, is it blowing any air or just no hot air.
Oct 28, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
2005 tahoe dual climate control, driver side blows HOT air.
You will need to replace the drivers side temp actuator. It is available at your local dealership.
Aug 30, 2009 | 1999 Chevrolet Tahoe
Blowing hot air on the driver side other vents cool air
disconnect the battery and try again to re sync the two sides, this is a common problem on all dual climate GM cars, if you can't get them to resync then you will need to replace the climate control head..
Jun 25, 2009 | 2003 Chevrolet TrailBlazer
Vw touareg climate control problem
Touareg passenger side only blowing cold air 2003 3.2 v6 dual climate control
Jun 02, 2009 | 2005 Volkswagen Touareg
Passenger side blows hot air when front control set to Air
you cant adjust it ,this requires the dealers computer to re set it,or a phyiscal control has packed up like a vacumn pipe has split where it pushes onto the valve that controls the flap in the heater unit.
Apr 25, 2009 | 2005 Dodge Durango
There is a thing called a blend door, it controls air temp, that is where the problem is, most common issue is the motor that operates the door fails.
Jul 28, 2008 | 2004 Chevrolet TrailBlazer
Air Conditioning and Heat for Hyundai Azera Logo
51 people viewed this question
Top Hyundai Vehicle Parts & Accessories Experts
Lawrence Oravetz
Colin Stickland
Colin Stickland
Are you a Hyundai Vehicle Part and Accessory Expert? Answer questions, earn points and help others
