Check the website for solution
https://printcopy.info/?l=en&mod=erc&brand=Canon&model=iR7095&code=E711-0001
SOURCE: error code E000732-0001 on canon imageRunner 3200n
this is a reader board error ... 1st check all connectors on the machine unplug and replug did this just happen or could there be a connector missing, this code usually comes from the connecter that looks like a small parrellel connector on rear going from scanner to right rear side
SOURCE: Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
