Question about Moen Posi-Temp Single HandleTub And Shower Faucet
Water hammer faucet cartridge - Moen Posi-Temp Single HandleTub And Shower Faucet
3 Suggested Answers
  • 105 Answers
SOURCE: I replaced my Posi-Temp cartridge for the shower
no one ever really figured out why this happens, but you can purchase a "hammer arrestor" to solve this problem. they work good and believe it or not they are best installed at shower valve. good luck
Posted on Jan 31, 2010
frank00802
SOURCE: Had a leaky Moen Posi-Temp shower faucet.
Yesterday, I also repaired a leaking bath/shower cartridge in a Moen Posi-temp faucet (mod. 1222). I couldn't locate a Moen cartridge so I bought one in Home Depot made by Danco (#88675A). My priority was to correct the water leak. Today I noted that when the commode fill valve shuts off, a noise (clicking) comes from the tub that I suspected as water hammering. I tried flushing the water lines to correct for air hammer several times without success.
So that brings me to this site and I see that someone else has experienced the same problem. To correct the noise, I'll need to get a Moen cartridge. Until then, my question is: IS THERE ANY HARM DONE by leaving the Danco cartridge in place?
I can get accustomed to the metalic/hammering noise whenever the toilet is flushed and the tub faucet is shut off.
Posted on Nov 22, 2013
Shower valve making banging noise pressure balanced even after changing cartrige
turn hose water off. open facet at lowest level to drain out lines. open a few faucets around the house to let air in. then close everything up. turn water back on. repressurize system by turning some faucets back on. see if it still happens. this is letting air back into any anti-water hammer devices that might be in system. sometimes they loose the air in them that makes them work. this should add air back in. good luck.
Mar 10, 2015 | Grohe Danfoss Tempress ll Tll Shower Valve...
Ever since I had This American Standard Williamburg shower control valve I get a terrible water hammer at comfort tempetures. My friend the plumber who installed it pulled the Pressure balance valve out...
NO DONT replace anything > You have what id call water hammer. This happends when water gets in the air chambers, Air chambers are nothing more than a 1 foot or 2 foot long section of pipe with a cap on it. When its working air gets trapped in the pipe and you can compress air but not water, so if the air is gone BANG BANG goes the pipe.
takes 10 mins to fix. turn off the water to the house out side. open every faucet in the house and the hose fauects out side. wait 5 mins and then close everything and turn on the water. You will see ait come out of the faucets it will stop after just a momnet or two.
That should do it. check your tub shower valve and it will work fine
Thanks for asking us to help
Hope this worked for you Tom
Sep 16, 2011 | American Standard R120 Pressure-Balance...
I have a Moen tub and shower system similar to the Moen 2919 Chateau two handle above. When I turn on the faucets up to 1/2 way everthing works fine. If I try to increase the water capacity by turning up...
To talk about your problem forces me to assume a few things.....If you allow the water to flow without cartridges and handles, the water must be flowing straight through the cartridge channels and out into the tub. It is not flowing through your tub spout or shower head when you test the water this way. If I'm correct, then the problem is isolated to the water mix operation. That means coming out of your spout or shower head. So now I have to ask a question. When you operate as normal (cartridges and handles installed) does your problem show up only on your shower head or does it also show up when operating out of the tub spout? If the problem is isolated to the shower head, try a head replacement. It may be partially plugged. If it's head or spout there may be something in the mixing pipe that only shifts around as pressure increases. I hope that is not your problem. It would require pulling those pipes out for inspection and most likely replacement. Nimsgame
Feb 19, 2011 | Moen 2919 Chateau Two Handle Tub and...
When turning on my American Standard single faucet I get a water hammer noise and my sprayer also jumps?
Replacing the spray diverter or faucet cartridge ( depending on your model) will fix the problem. Call American Standard and ask for free replacement parts.
Sep 09, 2010 | American Standard Plumbing
When hot water is turned on the pipes make this vibrating sound. i have two sinks in my bathroom. When I turn the hot water on on sink 2 the pipes vibrate. Sink 1 is fine.
There is a loose washer in the faucet...this flaps as the water goes through it and makes the vibration...
You either need to replace the faucet or the cartridge (washer) in the faucet that valves the water...
This will stop that vibration and hammering sound
heatman101
Aug 22, 2010 | Kohler Plumbing
I replaced a Moen shower cartridge with a Danco 88675 part. It stopped the leak, but ever since the repair I have water hammer in the pipes when I shut all the upstairs fixtures off. I have bled the...
The cartridge is the culprit. Replace it with an OEM Moen cartridge. What happens is that some replacement cartridges may not operate the same as the moen brand when they are in the closed position. This can sometimes result in the water hammer effect you are experiencing. Change the cartridge and it should alleviate the problem. If it doesn't work let me know and we will go at it from a different angle.
Aug 03, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Had a leaky Moen Posi-Temp shower faucet. Installed an Ace Hardware replacement cartridge. Fixed the leak, but now have a water hammer noise in the vicinity of the shower. Is this a common problem with...
I'm not aware of any problems with non moen replacement parts being the cause for a water hammer problem. Start with the simplest and cheapest correction which is using a moen replacement cartridge. If the water hammer persists then you may have to install a water hammer arrester in the plumbing system. This is basically a shock absorber in the plumbing system to stop the effect of water hammer. An arrester will cost you around $10 to $15 at your local plumbing supply shop. If you are not comfortable soldering copper then you will want to hire a licensed plumber to complete the work for you.
I had the same type of problem with an older toilet in my house. It developed a water hammer when it shut off after filling the tank. I replaced the fill valve with a generic universal replacement for about $10 and it stopped. Again sometimes the simplest fix will work. Let me know how it works out.
Jul 19, 2010 | Moen Posi-Temp Single HandleTub And Shower...
When the water is turned on, the faucet "sputters" and "hammers" as if the water had been turned off then back on when it hasn't been. Plumber says we need new part (inside cartridge 070807-Aqua Source)....
The USUAL cause of this is the diverter valve that channels the water to the sprayer. There are several types of these so search for yours in google to find a blow-up drawing of it. They are usually in the tower the spout swings on and sometimes are a pintle valve like a little rod with dumbells on the ends. Crud can make them not seat then they will cause the hammering.
Mar 09, 2010 | Danze D403412 Melrose Single Handle...
I replaced my Posi-Temp cartridge for the shower faucet. While the faucet now works fine, the pipes bang (water hammer effect)in the vicinity of the faucet every time someone shuts off the hot water. They...
Jan 22, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Our bathroom faucet ''chatters'' when you turn it on. What can I do?
this is a common problem its normally the copper piping inside the walls are not secured to the beams well enough and it causes water hammer in the lines...
if its only just started doing it recently you may get away with cleaning out your taps or replacing them but alot of the time you cant do much about it as the pipes are concealled in the walls
Jan 02, 2010 | Price Pfister Ashfield Single Control...
Moen Posi-Temp Single HandleTub And Shower Faucet  Logo
43 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
