Connect receiver to texecom d5084 - Audio Players & Recorders
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
May 09, 2016 | Pioneer Audio Players & Recorders
Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
May 22, 2008 | Yamaha RX-V2700 Receiver
I just want to fix my ipod on it
I'm glad to provide the instructions to connect an iPod to the Sony Receiver. Depends upon the model, it is possible that the iPod can be connected to a Sony Receiver using a Digital Media Port Adapter. Purchase the Digital Media Port separately, connect the iPod to the Digital Media Port Adapter and then connect it to the Receiver. However, some Receivers are not compatible for connecting Digital Media Port Adapter. In that case, you can connect the Headphone output of the iPod to the Aux/Line input on the Receiver.
Please provide the model # of the Receiver that you're using so that I can provide more information about the specific connections. Thanks for understanding.
Jun 17, 2011 | Sony Audio Players & Recorders
When you connect the HDMI cable from the TV to the receiver, is the receiver to and the TV to work pr is some other connection needed?
You can't connect your receiver to the television to get sound that way unless your television has an hdmi output. Your tv more than likely does not have an hdmi output. Those are hdmi inputs on your television. The way to connect the television to the receiver is to connect the red and white RCA outputs from the tv to the red and white RCA inputs on the receiver to get stereo sound. Now if your television has a digital audio out you might be able to get surround sound with connecting a fiber optic cable between the digital audio out of the tv and the digital audio in on the receiver, but this does not always work for all of the devices you have connected to your television.
The way to go is to connect all of your devices to the television's inputs for video and directly to the receiver for sound. The devices are connected from their audio OUT to your receiver's audio IN.
Feb 05, 2011 | Sony STR-DH510 5.1 Channels Receiver
How do i hook up to a tv
It depends on what connections does your TV have and what video sources you want to connect to the receiver.
This receiver doesn't have any video conversion capability. What you connect to HDMI-in of receiver, will be only on the HDMI-out. What you connect to component-in, will be only on component-out (and NOT on HDMI-out or anything else). So it doesn't make sense to connect any source via receiver other than HDMI - in such case, connect just audio (either spdif optical/coax or analog stereo) to the receiver and connect the video directly to TV.
For HDMI you can connect it via receiver, because this will carry both audio and video. Connect your sources (DVD player, sat box) to the receiver's HDMI-in 1-4 and connect HDMI-out to your TV.
Dec 27, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Connecting 2 sub woofers to denon 1506 receiver
Most receivers only handle one sub at a time. If you are deadset on connecting two, you might want to consider how much power your receiver will give to each if you split the signal then determine the power of each sub. If the subs aren't the same you can be sure they will sound strange.
If they are identical and your receiver has enough power to handle them both, examine the connection the subs use to connect to the receiver and split the connection by buying a splitter at a local radioshack.
You will probably be better off using the better of the two subs instead of having both connected. Your sound quality will be more balanced and clear when it comes to bass.
Mar 03, 2009 | Denon AVR-1506 Receiver
Intruder alarms
you get i tunes , then drag the songs that are mp4 over too i tunes.
Jun 17, 2008 | Computers & Internet
275 people viewed this question
 Grubhead
Grubhead
