Question about Epson AcuLaser C900 Printer
Epson C900 red light is flashing and green light constant
1) It began by displaying a flashing red light and static green light which in the book says "an easily recoverable fault". 2) I checked all the cartridges status and all was ok. ie: black, magenta, cyan & yellow. 3) Restarted printer still showing flashing red light fault and constant green led. 4) Removed photoconductor drum tested fuse and found it had blown so replaced unit 5) Restarted it then showed constant Red led and flashing Green, which book says is a protocol error so restarted it. 6) Now showing flashing red constant green. so installed another photoconductor drum. 8) Same fault lights again. 9) Replace all cartridges with new Epson items still same fault lights showing!
4 Suggested Answers
  • 79 Answers
SOURCE: Epson C82 & C84 Printers will not laydown any ink!
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The C82 in addition to clogging also has a problem where the waste ink hose which is supposed to remove excess ink (so the printer dosent get clogged) gets disconnected and so the printer clogs even more. The C84 had this glitch fixed but alot of good that did!
Thanks for reading!
Posted on May 01, 2008
  • 8 Answers
SOURCE: Epson Cartridge wont be recognised by printer
Check for the tape that wraps all the way around the cartridge bottom it usually has a red line on one end like a tab DONOT REMOVE THE ONE THAT LOOKS LIKE WIRES ON IT.... is it still there if so remove it.............MAKE SURE THE CARTRIDGE IS SEATED PROPERLY IT DOESNT TAKE ALOT OF STRENGTH TO INSTALL.....
Posted on Oct 14, 2009
yooperbud
  • 8637 Answers
SOURCE: Epson RX425 Ink Cartridge problem
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Posted on Jul 20, 2010
Printer was working fine and now it registers that there is a print in the queue and tries to start print cycle but then flashing red light comes on at the start of printing along with constant green...
Check the status monitor and see what further error message ... for this model, it's very prone to mech problem at the feeding area, you will need some tech know how to remove and repair.
Jan 20, 2011 | Epson AcuLaser C900 Printer
Cartridge red light stays on
I have not used my epson aculaser C900 printer for quite some time, I have now reinstalled it onto my new computer. The green light and the red light are both on (not flashing) any idewas please
Sep 29, 2010 | Office Equipment & Supplies
Problem printing multiple copies of a single page document
I have a similar problem with an old HP LJ1300. They have not updated the driver correctly and don't intend to fix it. I can't find any reference to AcuLaser C900 on Epson's support page. So maybe they stopped supporting the C900.
May 06, 2010 | Epson AcuLaser C900 Printer
When I try to print, a flashing red light comes on and the printer does not function. I cannot access the menu which gives the stus of the toners etc or instrcutions how to... so I cannot identiofy the...
check the toner ,, check paper jam and ,, paper tray ,, or any sensor issue,, don't give the print order untill you see the green signal over the printer...
Apr 27, 2010 | Epson AcuLaser C900 Printer
Epson c48 red and green lights flashing and not printing
hi c48 cartridge changed ,paper checked static red light on but no one is at home
regards john
Dec 04, 2009 | Epson Stylus C48 InkJet Printer
Flashing Green and Red lights
i querried from epson site it says the ink is low, repalce cartridge
Step 1 WHICH MODEL ARE YOU USING? Stylus C44UX Step 2 What were you doing when the problem occurred? Turning on the printer Step 3 What happened when you were turning on your printer? An error appeared on its control panel Step 4 What is the power light's current state? Flashing Step 5 What is the error light's current state? Flashing Step 6 WHAT IS THE PRINTER'S STATUS? Ink low
Oct 28, 2008 | Epson Stylus C44UX InkJet Printer
Start up cycle continues?
This is the normal start up procedure. The green light will continue to flash until it has completed the startup/warmup rpocedure.
Oct 15, 2007 | Epson AcuLaser C900 Printer
Error Code 6001 ~ 6999 are simply service required errors and are very general. I would imagine that if the tray is missing the printer will produce a fault. For starters it will think it has no paper and therefore will not try to pick up paper from the tray. If the tray is opened during operation I believe the printer stops, therefore there must be a sensor for the tray - no tray means sensor is operated. Best guess - fit a tray.
Apr 07, 2007 | Epson AcuLaser C900 Printer
Epson c900
Yup, they are right (they usually are) this is what the service manual says: (see http://www.TheserviceManualShop.com for a manual)
Apr 21, 2007 | Epson AcuLaser C900 Printer
Epson AcuLaser C900 Printer Logo
83 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
