Main screen displays Ready, instead of providor name (Nextel, Telus, etc.). Led flashes red at the same pace it usually flashes green when you have a connection. This is not the same as the solid red when there is no connection. When dialing manually or using history or contacts the phone will not dial (even with a good signal) and displays "Svc. Restr.". I have tired powering off and removing both the battery and SIM. How do I do a Master Reset?Main screen displays Ready, instead of providor name (Nextel, Telus, etc.). Led flashes red at the same pace it usually flashes green when you have a connection. This is not the same as the solid red when there is no connection. When dialing manually or using history or contacts the phone will not dial (even with a good signal) and displays "Svc. Restr.". I have tired powering off and removing both the battery and SIM. How do I do a Master Reset?
You can't post conmments that contain an email address.
Do you need Network Unlock code for Motorola I530 model Phone.? You can get the Network unlock code(Special code) at Prounlocking.com and unlock it from network lock easily..
To be able to send and reply to text messages you must have NOL net access. Press menu(left of the left arrow key), scroll to net, press ok(if an error message appears contact nextel for internet service), scroll to text messaging, press ok. From there you can write, read and reply to text messages. The reason for having to do it this way is because this phone as well as others with nextel were being produce when text was first being introduced to nextel, at that time motorola wasn't making nextel phones with the option of text, so it was up to the provider to give text access(via. net).
My screen says Ready and when I try to call it reads Svc.Restr. that all i get
Thanks
