Question about True Fitness 400p Electronics Only
E3 EEPROM error message
The treadmill periodically shuts itself down or starts speeding up. I can usually restart it, but now I only get the same error message E3 EEPROM. I unplugged for a while, but no changes.
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Torpedo treadmill e3 I turn on the treadmill, push start, an it counts down. Then E3 flashes in the time area. E3 continues to flash until you turn off the treadmill. Help!
You have to check the speed sensor of the treadmill. May it can be displace or can be dirt accumulated on it or the speed sensor would be faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 04, 2014 | Exercise & Fitness
Codigo de error
List of Error Codes for Precor Fitness Equipment
Error Code List for Precor Fitness Equipment
Feb 05, 2014 | Precor Exercise & Fitness
True treadmill 850p e3 EEPROM code
Normally the E3 is problem with the sensor speed.
Use the DMM tester, and prove the sensor with some metal and connect the DMM, with the 2 wires from sensor, if the Dmm in continuity mode BEEP, the sensor is Good, If NOT beep, the sensor is Faulty, Replace.
Blessing.
cuadra2016@yandex.com
whatsapp:+50588611441
Dec 16, 2013 | Exercise & Fitness
Precor treadmill code e3 is on
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 03 E03 EEPROM Test Error
Oct 18, 2013 | Precor C954 Remanufactured Treadmill
Stops 5-10 min into exercise; trips breaker,
Dear Sir:
Thank you by your request. I hope everything is o.k
Now I will try to help you.
You have electrical-mechanical Problem:
If you can walk on your treadmill but it shuts down during a workout, it is normally caused by a friction problem with the belt and deck.
Here are the most common symptoms and solutions:
Symptom: The treadmill operates for a given period of time and the circuit breaker on the treadmill trips causing you to have to reset the breaker, or let it cool off then reset the breaker. The
amount of time required to shut down will progressively get shorter.
Solution: The walking belt is worn. The incline test is the best test for it if you don't have a way to take a
DC amp draw. Put the treadmill at full incline and walk normally. If it takes it longer to shut off or does not
shut off at all, you need to replace the walking belt. Be sure to inspect the deck for wear too. If you want to
go for a cheap fix try lubricating the walking belt. The best fix is to replace the
walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill will show power but after a given period of time, the treadmill will simply shut
down. Once you let it cool off, you can restart it back up but it shuts down faster and the time required
before it shuts down gets progressively shorter.
Solution: Your treadmill is most likely equipped with a heat sensor which shuts down the motor and/or
electronics to prevent them from burning up. If this is the case, replace the walking belt. Be sure to inspect
the deck for wear too. If you want to go for a cheap fix (that we don't recommend) try lubricating the walking
belt. The best fix is to replace the walking belt and then regularly maintain it and keep the treadmill clean.
Symptom: The treadmill shuts down in an intermittent pattern...there is no rhyme or reason to when it will
shut down. I get an error code or nothing shows up on the panel. I have to either unplug the treadmill or
reset it to restart the treadmill.
Solution: If you get an error code, contact us with the code and make and model and we will try to help
you figure out what is going on. Typically we either find a loose wire, an intermittent short, a bad power
board, or a bad control panel in service calls that we do locally. Unplug your treadmill and then check all
your wiring to make sure nothing is pinched, crimped or loose. Remove and replace each connector in
case corrosion is causing the problem. If the problem persists, you most likely have a bad control panel or
some call it a console.
Thank you in advance, sincerely. God bless you.
If you need additional Help , please contact me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Sep 28, 2011 | Bowflex Treadclimber
Athlon iQ2 treadmill-just replaced motor control board including speed sensor. Get E3 error on attempting to start speed increase and everything shuts down. Help.Others insist this is a speed sensor...
If this is the same problem you had prior to replacing the MCB and speed sensor. I would check the drive motor, unplug unit then remove motor shroud then unplug the connectors leading to the motor itself. If you have wire leads and a 18v drill battery connect the leads into motor then attach the other end to you battery and if the motor will rotate ( approx. 1mph) , if it does the check speed sensor to see if the correct spacing between sensor and front roller ( check if the magnet has not fallen out of front roller pulley this also can cause you problems) hope this help!!
May 15, 2010 | Exercise & Fitness
E2, E3, E4 CODES ON A SEARS LIFESTYLER EXPOSURE 1500 MACHINE STARTS OK BUT SHUTS DOWN W/ E CODES AFTER A FEW MINUTES.
an E2 is a speed error code and the others all just tell me you have a friction problem-elevate the incline up all the way,without mtr working,push yourself off backwards-did you use muscles in arms/lower back? was it diffacult? thats friction,like rubbing hands together for long time. Result, no lube under walking belt- replace mtr,controller,walking belt- cost- a new treadmill
Jan 07, 2010 | Exercise & Fitness
TX 4.9 sportcraft treadmill
Info from PDF files located on Sportcrafts website under manuals.
E3 – No speed sensor reading. Unit shuts down. This is the most difficult repair diagnose. The speed
sensor is connected to the frame of the treadmill near the drive pulley on the front roller. There is a
small magnet on the side of the pulley wheel. The sensor tip must be no more than 5mm from the
magnet. If for any reason the distance is greater than 5mm the treadmill will shutdown
Adjust or replace speed sensor.
Treadmill: Speed Sensor Replacement
1. Make sure your treadmill is unplugged before you begin.
2. Remove the motor cover located in the front of your treadmill, it is held on by a few screws.
3. Locate your speed sensor; it is the small T shaped part with a red and black wire coming from it.
4. Remove the 2 screws in the speed sensor and remove the old sensor.
5. Place the adjustment holder on the frame with the open holes facing the pulley wheel, the prongs facing
up and way from the pulley wheel. Insert the screws but don’t tighten fully.
6. Now place the speed sensor over the prongs with the square part facing the pulley wheel and the red and
black wire to the far right.
7. Plug the treadmill back in and slide the speed sensor until it is 5mm from the magnet inside the pulley
wheel, you may have to do this several times until you can position it so it no longer shuts down. Use 2
nickels to figure out the spacing. The width of 2 nickels is 5mm.
8. Once you find the correct position tighten the screws all the way; being careful not to touch any of the other electronics
9. Place the motor cover back on and enjoy your machine.
Aug 13, 2009 | Exercise & Fitness
True Fitness 400p Electronics Only Logo
41 people viewed this question
Top True Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a True Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
