Question about Philips Televison & Video
Philips rc2034301 Does it lose code and need re coding or bin and buy new one can't see the red light when press buttons
5 Suggested Answers
  • 1694 Answers
SOURCE: need code
www.remotecodelists.com hope that helps .........T.
Posted on Mar 19, 2008
XRAYRON
  • 156 Answers
SOURCE: code for apex tv through philips universal remote
Try these APEX TV codes 0023 0223 0123 0741 Thats from the CL034 Code book
Posted on May 02, 2008
jas247
  • 844 Answers
SOURCE: turn on device i pressed
Welcome to FixYa.
If you're entering the 004 code, your TV might be an EMERSON. Try the followong codes as well:
Emerson TV Codes: 004, 009, 014, 023, 024, 025, 035, 036, 037, 038, 039, 040, 041, 042, 043, 045, 049, 051, 053, 116, 135, 147, 155, 177, 179, 189, 198.
Thank you for using FixYa.
Jas247
Posted on Sep 09, 2011
  • 53 Answers
SOURCE: remote code
have you tried googling philips universal remote, also try this website: http://www.remotecodelist.com/remotes/philips/philips_pmdvd6.html
it has a lot of good codes.
good luck
nouvelle tablette pc
Posted on Feb 14, 2012
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
I need manufature codes for philips RC2034301/01 to progrma URC-8203
If you wish to get more codes and other details check:
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 19, 2014 | One For All URC-3021 Remote Control
I have a gate house electronic keypad deadbolt, but I lost the book. I need to know what to enter to change my passcode
Try this:
1. Press [SET] button for more than 2 seconds.The red LED will light and the lockset will beep twice.You are now in programming mode.2. Enter 123456 (or current programming code) and then press lock button. The red LED will light continuously for 10 seconds.Enter new programming code (six digits) and then press lock button. The red LED will light continuously for 10 seconds. The new programming code is effective.
Dec 04, 2012 | Locks & Locksmithing
Universal Remotes
If there is setup codes for your TV brand with the code list of the remote control you bought, it should synchronized with the TV. If there is no code, you can try a code search method. Even if it do not help you, you must have to buy an other one.
Code SearchIf after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
Aug 29, 2012 | Televison & Video
I have a Defiant Electronic deadbolt from home Depot. model G1X2D01. ive lost the manual and i need to delete some old codes from it.
Snap off the back cover (opposite where you punch the numbers) by pinching the sides and pulling off. Do not press a pen or anything into the small light, you do not need too. Just pinch and yank off cover. You will see a small light and beside it is a small SET button by the batteries, it is labelled.. Press this Set button for 2 seconds. The red LED will light on the front code side and beep twice to indicate you are in programming mode. Enter your current code that you want to change (factory set is 12345) and then press the button that looks like a little lock on the keypad. Enter the digits "10" and press the lock button again. Enter the new code (must be six digits) and then press the lock button again. The red light should go on continously for 10 seconds. The code should be effective.
Note: if you have problems like we did, you can also remove one battery and press the "set" button simulataneously when you reinsert the battery. This resets the factory code of 12345. Then you can start over. For some reason our old code was only 4 digits, but it would not let us reprogram a 4 digit code. It didn't work until we did a 6 digit new code.
Apr 15, 2012 | Locks & Locksmithing
Need the universal remote code for the phillips dfr 1600
Hello
Three digit codes for Philips are
PHILIPS Codes: 003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
philips magnavox are:
PHILIPS/MAGNAVOX Codes: 183/ 184/ 208/ 213
Four digit codes for philips are:
PHILIPS ........... 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
PHILIPS-MAGNAVOX ..... 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
May 02, 2011 | Audio Players & Recorders
Need a new remote. were to purchase one at. my remote is bad after replacing the batteries i checked the remote with my video cam and found the remote is bad
Hello
Just buy one PHILIPS CL 034 universal remote control Duraband is listed it its codes. Codes are:-
.......... 0520 0115 0317
........................... 0916 0027 0447 0323
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
flashes.
OK
Mar 05, 2011 | Durabrand HT-3915 System
I need remote control
Hello
You just buy one Philips Universal Remote Control. Model number [ Philips CL 034]. JVC has been listed in its codes. I hereby send codes also.
0607 0204 0321 0508 0326
0993 0802 0108 0308 0715
Direct Code Entry
button.
flashes.
OK
Dec 08, 2010 | JVC AV-32020 32" TV
I need the codes to install on a new tv
To search for the control codes that will work on your new TV, follow these steps:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. The LED light will turn off, and your remote is programmed for your new TV.
Hope that helps.
Oct 07, 2009 | Innovage Jumbo Remote Control
I HAVE LOST THE MANAUAL FOR MY PHILIPS MAGNAVOX UNIVERSAL REMOTE
You don't need the whole manual for the Philips Magnavox remote fortunately.
If you want to reprogram it for the Apex TV, follow my directions exactly.
  1. Hold down the Code Search button (on the remote) until the light on it turns red and stays red.
  2. Let go of the Code Search button.
  3. Make sure to switch modes at this point to which device you want to program, I'm going to assume TV Mode since your post says "Apex TV." If you need help with Apex DVD codes, I can answer that one too :)
  4. As you Press the mode button and release it, the light should blink for a bit, so keep your eye on it because after it's done blinking it'll stay red.
  5. At this point the remote want's you to press a sequence of numbers also known as Code[s] or Code Entries. Either way these are what are in a table inside the manual that you lost.
  6. I'm going to give you two codes in case one doesn't work: 044 and 335 (one of those hopefully will work)
  7. If the code worked you'll know right away because the light will get mad and start blinking again, otherwise if it DID work, it'll just turn off (the light will anyway).
  8. That's it, I reccomend you test out your remote with the TV now and make it everything works. If something doesn't, try the other code. If it still doesn't work right, I'll give you some more codes.
Hope that helped,
-Cheers-
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
3. Enter the 3 digit code from the code tables. Note:
4. With your device on, press CHANNEL Up. If the
equipment, try one of the other codes for your
brand.
APEX 044
Mar 21, 2009 | Philips Televison & Video
Televison & Video Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
