Question about Whirlpool Dryers
I am getting a FO3 and a EO1 error code
I have a Whirlpool Duet Steam HE Sensor Dryer and I am getting an FO3 and EO1 error codes flashing on the display. It will run for a little while then shut off and give these codes.
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Duet dryer error code
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Posted on Aug 05, 2008
localwonder
  • 6784 Answers
SOURCE: whirlpool duet dryer error code e1
HI, the Thermistor has failed. replace it asap. this will fix your issue.
Posted on Aug 01, 2009
protek480
  • 1714 Answers
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Posted on Sep 25, 2009
SOURCE: Error code E6 on a Whirlpool Duet Dryer
Whirlpool Duet electric dryer only dries clothes on heavy duty selection. what is wrong?
Posted on Jan 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Whirlpool Duet dryer and it cut off and
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
How can I get my dryer running?
You need a new machine control board
Oct 02, 2016 | Whirlpool Dryers
My Whirlpool Duet Steam dryer starts, but then stops a few seconds later. What is this indicating?
Likely a broken sensor or bad power relay... There are no error codes along with the failure? Model #? Help Me Find My Model Number RepairClinic com
Jul 19, 2016 | Whirlpool Dryers
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    On Whirlpool duet steam front loading DRYER...What does the error code F70 mean?Do you have to have a certified whirlpool appliance service professional to repair?
    F70 code says...
    Replace the machine control electronics. You should first unplug the machine and then remove and plug back in all connectors on the front panel model as well as the electronic control module.
    If that doesn't take care of the problem then it may be time to consider replacing the rear board. The FSP # 8183259
    The control board is part # 14 in the link below.
    Sears parts direct /Whirlpool-Parts/Model-WFW9400VE01
    Mar 13, 2015 | Whirlpool Washing Machines
    What is a flashing F23 Error
    blank.gif F23 Pressure switch failure Should the main electronic control unit detect that the wash level contact (or level) is on and the switch level for wash heater safety is off for any more than ten seconds during a wash this error code will be displayed.
    Resetting the program may clear this error but unlikely.
    • Check the pressure switch or sensor for operation and electrically
    • Check the wiring from the main electronic control card to the level sensor
    • Check all connectors between the main controller and pressure switch
    • Run test program
    • Also see F08 and F12 as heater failure can cause this error to occur
    Nov 12, 2014 | Whirlpool Duet Steam WFW9700V Front Load...
    Error code F-35 is showing on my whirlpoot steam duet stackable front load washer, what does that mean? It won't run through any cycles.
    it is an analog pressure sensor failure theres a malfunction with the steamer component detected by the steamer electronic board
    check if pressure hose is fixed correctly
    check if the airtrap is not blocked
    check if the hose is not blocked
    hope this helps if this doesnt work write me back
    Jul 21, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
    Dryers Logo
    126 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
