Question about Black & Decker String Trimmer Cordless 12" 18V
Factory wound auomatic feed spool isn't feeding and seems to melt together
GrassHog electric trimmer GH600 type2 Automatic Feed Spool often seems to melt together and isn't feeding.
3 Suggested Answers
SOURCE: auto feed spool doesn't work
10 to 1 yours is doing what mine is, line comes out all over... I think there is a little spocket on the center shaft under the spool... When I replaced line I lost this part and know one shows this as a part on there web sites... I don't know what to do??????
Posted on Oct 13, 2008
  • 9 Answers
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Posted on Feb 21, 2012
When on edger spool feeds all the time. The roll only lasts about a
you either have the spool wound wrong or loose also could be a bad feed head
Jun 18, 2015 | Black & Decker Black and Decker & Grass...
My bump knob on my Ryobi elect trimmer turns although very tight and turns the bolt but is not undoing. Any solutions please
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Oct 31, 2011 | Ryobi 15" Electric Factory Reconditioned...
Black and Decker electric trimmer (grass hog) model GH600...eats thru line, one spool lasts about 3 minutes
It sounds like that the automatic line release is damaged.
1. Remove and clean all debris from the head. I assume that you have already done this if you have changed the line a few times, but just make sure.
2. Remove the the head from the shaft.
3. There should be a large spring in there. If its broken, damaged or missing that will allow the head to spool line pretty fast. again make sure all debris is removed from this area.
4. Check the feed dogs in the same area as the spring. If they are worn the same problem will occur.
5. Install line on the spool.Make sure that it is wound the proper direction. There should be arrows indicating this. The line wound in reverse will also cause the same problem as well.
6. Put it all back together and see if works now.
7. If this doesn't solve it you may need to replace the head assembly.
Jul 02, 2011 | Black & Decker Black and Decker & Grass...
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Aug 24, 2009 | Black & Decker 14" Grass Hog Xp...
Line gets tangled in gear under feed spool
Problem solved. We noticed something was broken off a small part inside the spool holder. My husband took it to the local hardware store, and one of the employees gave him the part from a trimmer that had been returned.
Apr 06, 2009 | Black & Decker St7000 13'' Automatic Feed...
Auto feed spool doesn't work
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Corded black and decker trimer
Please check your line diameter. If you are using stronger line than specified in the manual, it could be the root cause.
Aug 08, 2008 | Black & Decker String Trimmer Cordless 12"...
My grasshog gh600 wont feed the line anymore. i replaced the cap, spring and purchased a pre-spooled line to see if that was the problem. it wasn't. please assist
check out a white plastic lever at the back of the spool line. if its broken then replace it. cost of the parts around $4.00 or so. this parts controls the auto feed of the spool
thanx
Jun 24, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
346 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
