Ketron x1 what does 6 pat file corrupt mean - Computers & Internet
My Ketron Sd5 seems to play a different key on the right than on the left. For example if I play a beat in the key of G (left) the right hand side plays in A. Can you help?
You need to check your manual for instructions on key transpose. The right side has been transposed one key higher. If you don't have the manual, try resetting the instrument by removing the internal battery and reinstalling it. Good luck!
Aug 01, 2016 | Ketron SD5-61-Key Arranger Workstation...
How to update a corrupted HP v165w drive
What do you mean by "update?" If it's corrupted physically as in bad sectors, then you replace, or turn in for warranty repair.
If files are corrupted, then run fdisk /f from the command line to check for file corruption. If the systems files are corrupt, simply run sfc /scannow from the command line.
But you really should supply more information if you want a decent reply.
Apr 28, 2014 | Computers & Internet
Corrupt Outlook 2010 pst file
If you are searching a tool that really helps you in resolving Outlook corruption, use Recovery for Outlook PST repair software which recovers emails from broken PST and the PST corrupted due to size limitation error.
To know more visit :-
Outlook PST Repair
Nov 12, 2013 | Microsoft Outlook 2010 for PC...
Disk to fat converter
Your hard drive via USB connection did not power on your hard drive so your PC can't detect the drive. I don't believe the cause is your software. Try another UBS port, if that doesn't work power down your PC, connect your drive and boot up to see if the program detects the drive.
Nov 05, 2013 | Computers & Internet
How to fix a corrupted file so windows will work
Code is a memory address. Use system restore to correct corrupted file from .cab?
Mar 30, 2012 | Computers & Internet
Following files missing or corrupt: \windows\system32\config\system
Well this means one of important files needed to start Windows is corrupted (it's a registry file).
I'd recommend repairing Windows installation. If you have Windows XP and also the Original Windows CD follow: this guide.
Dec 31, 2011 | Dell OptiPlex 740 (BPCW6TT) PC Desktop
The file is corrupt and cannot be opened
Probably the file IS corrupted. This means the file was copied (or downloaded) incomplete or unsuccesfully. Try copying/downloading the file again and opening it.
Jul 26, 2011 | Microsoft Computers & Internet
Can not find yahoo mail page
Try www.yahoomail.com
Dec 04, 2009 | Yahoo Mail
The save file has been erased due to corruption or damage message appears at start.
The message means exactly what it says. The save file has become corrupt; meaning part or all of the memory that the file has been saved on went bad.
You will have to start a fresh game - sorry
Good Luck!
Aug 07, 2009 | Nintendo Video Game Consoles & Games
How do you retrieve corrupted files on a DS-3300
If the files are corrupt then you could only retrieve corrupted files which would be useless.
Sorry.
Feb 24, 2009 | Olympus DS-3000 Digital Voice Recorder
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
